Old 26-08-2007, 01:21 PM   #1 (permalink)
digit i am thinking's Avatar
Default Intel or AMD based Laptop?
I just finalised two laptops
Compaq Presario V3424AU
Compaq Presario V6406TU
specifications of Compaq Presario V3424AU
Processor type
AMD Turion™64 Processor MK-38 (2.2 GHz)
• 2.2 GHz, 512 KB Level 2 cache
the Compaq Presario V6406TU Notebook:
# Microprocessor: Intel Celeron-M 520 (EM64T)
Mobile Power Management
533 MHz Front-side Bus Speed
# Cache Memory: 1 MB Integrated L2 advanced transfer cache
Which one processor is good of these two AMD and INTEL?
or Rather which Laptop should i go for?
digit i am thinking is offline
Old 26-08-2007, 01:27 PM   #2 (permalink)
kumarmohit's Avatar
Default Re: Intel or AMD based Laptop?
Turion is better than celeron, if it had been C2D frrom intel, the story wud have been different
kumarmohit is offline
Old 26-08-2007, 03:52 PM   #3 (permalink)
I heard that Compaq Presario V3424AU has got problems with NVIDIA® GeForce™ Go 6150 is it true.
Also Can i able to install XP on it?
Old 26-08-2007, 05:49 PM   #4 (permalink)
dude with 512 ram on vista is vry vryy slow ... so put 1 gb atlest
hackers2005.3721 is offline
Old 26-08-2007, 06:00 PM   #5 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
better get c2d man.1.7ghz will be good if u r on a budget.from these 2 turion is much better
Apple Macbook Pro 17
nish_higher is offline
Old 26-08-2007, 06:04 PM   #6 (permalink)
M$™ Certified Spammer
entrana's Avatar
dude dont get compaq at all i have like 5 different compaq products all which i am facing problems with i mean i dont own all just 1 buy my brothers and sister own the rest
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 26-08-2007, 08:29 PM   #7 (permalink)
The turion processor comes in Compaq Presario V3424AU which has Vista installed.But i don't want vista,i want XP or may be free dos.
So what shuld i do? Should I format it after buying and then install XP?
Old 26-08-2007, 08:30 PM   #8 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: Intel or AMD based Laptop?
Processor type
my personal experience go for Intel
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 26-08-2007, 08:33 PM   #9 (permalink)
nishant_nms's Avatar
vista will run fine but no up to mark.
U may format and install XP if u will.
Overall the AMD offering is gr8 in the two
nishant_nms is offline
Old 26-08-2007, 08:46 PM   #10 (permalink)
Compaq Presario V3424AU offers NVIDIA® GeForce™ Go 6150 Video adapter
While Compaq Presario V6406TU offers Intel Graphics Media Accelerator (GMA) 950
So which one is better?
Old 26-08-2007, 10:15 PM   #11 (permalink)
entrana's Avatar
the first one if u had to choose
entrana is offline
Intel Support Directs me to use DDR-II in DDR based board !! Choto Cheeta Technology News 39 15-07-2007 12:48 AM
Intel based Comp shwetanshu CPU / Motherboards 2 21-09-2005 06:48 PM
does intel 915 chipset based mobo supports hardware T&L arunbj CPU / Motherboards 5 26-07-2005 07:25 PM
915 chipset based intel motherboards anoopingenius CPU / Motherboards 3 09-10-2004 09:16 PM
