Old 25-08-2007, 09:49 AM   #1 (permalink)
Default Urgent: scanner problem
Hi,
I have an old Acer 3300U which stopped working and started making some clicking noises. On opening it up, I found out that the belt was loose. Is it possible to get a new belt for the scanner? Where in Mumbai? I don't really want to buy a new scanner since my use is very occasional.
If I have to buy a new scanner, which is the cheapest reliable one? Requirements are mainly document scanning of important papers for archival (home use, so occasional).
Can't buy an all-in-one because I have a 6 month old printer (didn't buy an all-in-one then because I already had a scanner!!!).
I would appreciate a quick reply since I would like to take a call today.
Thanks
Vikram
vikramk is offline
Old 25-08-2007, 10:22 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Urgent: scanner problem
I think you should visit acer service/ support center for best solution.
www.9zap.com/forums -> Indian Webmaster Forum
whost.in - Web Hosting Offers
thinkdigit.com/forum/showthread.php?t=109137
TechTin.com
ravi_9793 is offline
Scanner Problem vineetrocks2005 Hardware Q&A 12 24-01-2007 07:29 PM
scanner wizard problem. jojoji_jojo Peripherals 5 18-09-2006 07:45 PM
Entry Level Scanner??? Urgent Aseem Nasnodkar Peripherals 4 05-05-2006 08:05 AM
Big Problem(Urgent) imported_shivam Buying Advice 3 10-04-2006 12:08 PM
scanner problem.. abhishekkalra Hardware Q&A 2 11-01-2006 12:52 AM
