Old 25-08-2007, 12:22 AM   #1 (permalink)
Default Advice needed for upgradation
hi, every body.It's been almost 3 years since i bought i my PC.Now iam considering an upgradation.My current configuration is as follows:
Processor:AMD ATHLON 2400 XP
Motherboard:ASUS A7N266VM-SE
RAM:256 MB
Graphics Card:ATI Radeon 9200 SE (128 MB)
Sound Card:Sound Blaster Audigy
Speaker: Creative Inspire 5300
Now i need to have a new Core 2 Duo configuration where most of games available currently can be played decently.Iam currently not planning to change my graphics card.But i may change it in another 3 to 4 months.So please advice on the graphics option also.My budget is around 15000
arun.s.menon is offline
Old 25-08-2007, 12:51 AM   #2 (permalink)
slugger's Avatar
Default Re: Advice needed for upgradation
ur GPU is AGP
so if u wan2 use it for sum time den u will have 2 buy a mobo dat supports both AGP+PCIe
such mobos r no longer released by mfg, so u will have 2 settle 4 a relatively older mobo
i had made an observation about a similar problem just today
u mite b intrested in taking a look HERE
as 4 d remainin suggestions regarding d other hardware 4 ur rig u shud look @ d first sticky in this section that has been started by our beloved always_prowlin_d_forum_in_stealth cheeta
slugger is offline
Old 25-08-2007, 03:05 PM   #3 (permalink)
can someone please explain me the difference between PCI express and AGP.
And if i have to buy a new PCI Express card, please tell me a good card which could be included in my budget of 17,000
Old 25-08-2007, 03:28 PM   #4 (permalink)
slugger's Avatar
all u now need 2 no now is dat
AGP is obsoltete
PCIe is d current standard 4 GPUs
if u want more explanation, just google
4 17000 u shud get a 8800GT
but u may wan 2 wait for 4-5 months bcos MS may introduce DX10.1 standard thus makin all current DX10 cards incapable of playin games developed usin d latest DX10.1 standard
slugger is offline
pc upgradation suggesitons needed dotcommakers Hardware Q&A 1 16-04-2006 11:47 PM
Advice needed arora_parth QnA (read only) 5 08-09-2005 09:19 AM
Advice needed arora_parth QnA (read only) 4 03-09-2005 12:21 PM
RAM UPGRADATION ADVICE mahendran QnA (read only) 4 05-07-2005 06:24 PM
