| Forum |
#1 (permalink) |
Posts: n/a
#2 (permalink) | |
ok take out d battery form d mobo and keep d mobo i dat stat 4 around 2-5 mins if ur mobo needs u 2 take out d jumper 2 reset d BIOs den do dat but i think d battery is enuf gud luk hope dis is enuf 2 save u from gettin spanked by ur DAD |
#6 (permalink) |
The battery is like a round metal coloured plate like thin cell. Theres a lock at its edge. take out anr replace after 60 sec and ur bios has been reset.
see da image
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. Last edited by dOm1naTOr; 24-08-2007 at 11:58 PM. Reason: Automerged Doublepost |
#7 (permalink) |
Posts: n/a
i have waited for about 15 minutes by taking out battery and jammer but no use.......
i may leave this site soon and will get a beat from my father.... i have waited for about 15 minutes by taking out battery and jammer but no use....... i may leave this site soon and will get a beat from my father.... Last edited by bigdaddy486; 25-08-2007 at 12:11 AM. Reason: Automerged Doublepost |
#8 (permalink) | |
and r u sure u took out d correct jumper PLEASE refer your motherboard's manual to see exactly which jumper is ment for resetting the BIOS, the motherboard has lots of jumpers in it for doind many things u must takeout d correct jumper |
#9 (permalink) |
Posts: n/a
anyway, after your all advice and my hardwork for 4 hours, i rescued myself from my father and my cpu also.....
what i have to do is take out the jumper and battery as mentioned and also, i have to place my cpu vertically and put on the jumper and battery Oh, now its another problem -it shows that it didn't find any harddisks..... Last edited by bigdaddy486; 25-08-2007 at 08:10 AM. Reason: Automerged Doublepost |
#10 (permalink) | |
u obviously have 2 put d jumper and battery back into 2 mobo after takin it out as 4 d second problem [HDD] just push d data and power cables back firmly in2 d sockets remember, firmly but carefully |
#11 (permalink) |
yup, it might be some loose connection. Recheck the data cable nd power connector of the HDD.
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. |
#12 (permalink) |
Posts: n/a
thats not the problem, i have changed its configuration into raid and when i changed it inti ida, it worked but i couldnot use intergreated graphics becaise whenever i install the driver and reboot, there is no display. also, plz tell me how to configure my sata harddrive into raid and what is its use?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
