| Forum |
LinkBack (1) | Thread Tools | Display Modes |
Pee into the Wind...
![]() This means I can't transfer any data to my card.Data transfer from card to PC takes place properly though.I can't even format the card using card reader because of it.I use Nokia 6630 and 1 gb card. Does someone know of a solution.?? .This problem is driving me nuts.
Life is as complicated as you say it is. |
#2 (permalink) |
Dreamweaver
disable the write protect of ur card
Today's noobs are tomorrow's geeks. Don't make fun of them.. encourage them. - Gigacore Follow me on twitter.com/gigacore |
#4 (permalink) | |
Web developer
mmc doesnt have write protection, afaik. it might be password protected using some app or password protection. if you can find a camera which supports mmc & format it or use a card reader which formats protected cards. can u format it in the phone? also remove the card properly from the phone after it closes all the apps and displays that you can remove the card.
#5 (permalink) |
The MMC is not password protected.I formatted it a dozen times already from my fone.But just after formatting if I put the card back in,it comes up with the same error.
#6 (permalink) |
Dreamweaver
so time to get a new one
#7 (permalink) | |
C2D E8400, MSI P45 Neo-F, Sapphire HD4850, Dell 2409W, OCZ 2*1GB RAM + 1*2GB Transcend + 1*1GB Transcend , Seagate 1TB + 2*Seagate 80GB, 600W SMPS, APC 600VA, Creative EP630, Sennheiser HD202 |
#8 (permalink) | |
#9 (permalink) |
@ narangz: thnx for the info buddy.The tape trick worked!!!!
You and all others deserve credit for helping me out.
#11 (permalink) |
nah.. dat shouldn't happen.. make sure dat not even a small piece of the metal is exposed !!.. that oughtta do it!!
#12 (permalink) |
Do one thing.
Go to My Computer.Right click on your memory card.Navigate to Properties>Hardware.Select your Memory card from the list.Click on Properties>Policies>Optimize for Quick Removal..Save the settings.It worked for me. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/66461-disk-write-protected-error.html
| Posted By | For | Type | Date | |
| Disk is write protected error Hardware Troubleshooting Question | This thread | Refback | 30-08-2010 12:54 PM | |
| Pen drive error messg"Unable to open Script file "F:\MSDLL.dll.vbs" | janitha | Software Q&A | 19 | 20-04-2007 10:25 PM |
| How To write movies in DVD " AS A DVD" | vikasg03 | Software Q&A | 1 | 20-04-2007 12:25 AM |
| "Hard disk Failed Press H to retry or enter to boot from other device " | uzair | Hardware Q&A | 7 | 01-04-2007 12:33 AM |
| Windows cannot find "rose.exe" error, when accessing Hard disk drives ! | vishesh8 | Software Q&A | 14 | 11-01-2007 10:01 PM |
| "INF Error", VGA Driver "Missing" Installing ATI Catalyst Drivers | CannedLizard | Hardware Q&A | 4 | 29-07-2006 12:47 AM |
