Old 24-08-2007, 07:18 PM   #1 (permalink)
Default Update Firmware
hi,
How do i update some settings permanently into a router.
I have UT300RTU ADSL modem , iam using the single conenction by conencting the router to hub then to two PC's . I am ablt to access the net by setting the router in Rotuer mode by saving ID and password in the router. But, sometimes when i switch off the router suddenly i.e incase of power failure.. the default BSNL settings are coming up and i have to reconfigure.. whts the solution to this ..
topramen115 is offline
Old 24-08-2007, 11:04 PM   #2 (permalink)
Web developer
narangz's Avatar
Default Re: Update Firmware
u can update the settings permanently using a configuration file, i guess or just update the firmware if its available at manufacturer's site
narangz is offline
liteon firmware update ayush_chh QnA (read only) 3 12-07-2007 03:59 AM
cannot update firmware gau_pppu Hardware Q&A 17 17-01-2007 12:51 AM
DVD recorder - Firmware Update parimal_xp2003 Hardware Q&A 3 02-10-2006 11:14 PM
Is Any Firmware Update Available For 7610 ? clmlbx Mobiles and Tablets 4 15-09-2006 07:52 AM
