Old 24-08-2007, 02:38 AM   #1 (permalink)
Default Ups Troubleshooting
gUYS I bought a 500VA UPS a few months ago.Now the problem is whenever the voltage fluctuates the computer reboots !!!
Has anyone come across such a thing ?
My configration is Pentium 4 -1.8GHz,2 hdd one from seagate 160GB and Samsung 40GB,17'' CRT monitor,2 dvd writers.
And has anyone tried connecting the UPS to a voltage stabliser instead of directly to the mains ?I s that harmful to the PC OR THE UPS ?
hari1986 is offline
Old 24-08-2007, 05:50 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Ups Troubleshooting
Time to take the UPS for Warrenty
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 24-08-2007, 06:48 AM   #3 (permalink)
Dreamweaver
Gigacore's Avatar
^ and get a replacement
Gigacore is offline
Old 24-08-2007, 08:47 AM   #4 (permalink)
slugger's Avatar
UPs mfg ALWAYS ask consumers 2 connect d UPS DIRECTLY to d mains and not thru other electrialc devices
and ya take it 2 d servvice center and get d problem fixed
u shud not b facin such a problem [defeats d whole purpose of usin a UPS ]
slugger is offline
Old 24-08-2007, 03:37 PM   #5 (permalink)
Guys it is an APC 500VA UPS and they replaced me with another one.The replacement too has the same problem.So guess it is not the UPS fault !
Earlier I used a Wipro emerge UPS and it could take on the voltage fluctuations easily.When i contacted them they told that it is due to voltage problem.so that leaves 2 questions
either APC is not yet suitable for the type of voltage fluctuations in india
or wipro has some other way of dealing with this type of voltage !
hari1986 is offline
Old 24-08-2007, 07:09 PM   #6 (permalink)
May be battery problem. Try switching off the power supply when computer is switched on and see if UPS is able to provide backup. If not , replace your battery.
ThinkFree is offline
Old 24-08-2007, 07:54 PM   #7 (permalink)
slugger's Avatar
AFAIK APCs 500VA UPS has 3 sockets in it
2 sockets - surge protection+battery backup
1 socket - only surge protection
d sockets r grouped together and seperated by a whit line on d UPS body
d CPu and monitor must b connected to the surge protection+battery backup sockets
i get a feelin dat u have attached d CPU plug to the surge protection only socket
check it out and c wat happens
slugger is offline
Old 24-08-2007, 08:01 PM   #8 (permalink)
Try connecting the monitor direct to the mains and the system to the UPS. Just try and see what happens.
V.Prem Kumar
janitha is offline
Old 24-08-2007, 08:39 PM   #9 (permalink)
slugger's Avatar
LMAO
of wat GOD-dammed use is a UPS if u have 2 connect d monitor 2 d mains
his config is by no streach of imagination power-hungry enuf 2 not b able 2 b coped by d UPS
also d guy said dat he was given a full replacement 4 d old UPS so d UPS ought 2 b in full workin condition
slugger is offline
USB troubleshooting! dreamzchm Peripherals 1 22-05-2007 05:42 PM
CRT Monitor Troubleshooting AstroD Hardware Q&A 6 11-03-2007 12:15 AM
Troubleshooting XP installation.... rvgopal85 Software Q&A 10 24-09-2006 02:37 PM
IE TROUBLESHOOTING subhayu Software Q&A 5 02-12-2005 03:56 PM
Who Knows Troubleshooting ? imprince QnA (read only) 9 07-12-2004 12:25 AM
