| Forum |
#1 (permalink) |
Whenever i plugin a USB stick or iPod to my USB port, i get a POP UP like this: HI-SPEED USB DEVICE PLUGGED INTO NON-HI-SPEED USB HUB How can i resolve this issue?. Please advice. |
#2 (permalink) |
"The Gentleman"
assumin u hav xp, if drivers r missing ... install usb 2.0 driver, or isntall windows usb 2.0 update.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense." - Dijkstra |
#4 (permalink) |
my motherboard is A7N266 VM-SE.I think the problem is that My USB is version 1 which is causing the problem.If that is the case, is there any way i can upgrade my USB port to ver 2.0?
#5 (permalink) |
hey guys even i wanna know how to determine the usb port speed....i have P5N32 E SLI mobo....and wanted to know whtr the front USB is version 1.1 or 2.0
as it is creating problems when i connect my ipod..... |
#6 (permalink) | |
Wire muncher!
A7N266 VM this mobo has usb 1.1 controller. for usb 2.0 you need to buy a usb 2.0 pci card.
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com Last edited by infra_red_dude; 25-08-2007 at 12:24 AM. Reason: Automerged Doublepost |
#7 (permalink) |
Get a USB 2.0 PCI card, will go in the PCI slot and give you around 4 high speed 2.0 USB ports...its damn cheap..i got one for like 250 bucks..and worth it...gr8 transfer speeds...arnd 480mbps...
If u think u r right...u r a bad thinker! |
#8 (permalink) |
well my ipod problem is still not solved.......i plugged my ipod in the back of my mobo...but the USB is not directly on the mobo (its actually an extension giving 2 USB ports)....i had read somewhere on the manual or on the apple website..that the ipod needs to be connected directly to the motherboard to work properly....so that means dont plug it in the front USB port. plug it in the port next to where ur LAN port is.
One more question...would it be ok if i keep my ipod dock connected in my comp at all times?....without the ipod i mean. its very annoying to get down and go behind the table to connect the USB cable...lol.. Last edited by moshel; 25-08-2007 at 08:04 AM. Reason: Automerged Doublepost |
#9 (permalink) |
Wire muncher!
what is the problem wid ur ipod? i can't see any reason why someone can recommend connecting the ipod to "onboard ports" and not external ones...
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#10 (permalink) |
Install SP2 for windows. Then all ports will be used as USB 2.0 unless ur PC is some Pentium 2 class.
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. |
#11 (permalink) |
ok well finally everything worked...i was getting the 1418 error in itunes and songs were not getting loaded. finally i searched through apple support and i was told to re-register .dll files by creating a bat file. i did that and it worked.
@infra_red_dude, apple says it on its website. they actually mean to say is that it is preferable to connect to the USB ports on the mobo. |
#12 (permalink) |
Wire muncher!
^^^ thats really strange. can somebody explain the logic behind that?
#13 (permalink) | |
Fast 'N' Furious
@ moshel
ToPsPeEeD = FaSt BuT StEaDy AMD Radeon HD 6850 OverClocked to 1 Ghz !!! Blog : http://topgeartopspeed.wordpress.com/ ---------------------------------------------------- Never buy viewsonic products : http://tinyurl.com/ykwx4oa |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Problem With Data Recovary Software Problem Stellar Phoenix | njm | Software Q&A | 1 | 08-05-2007 12:31 PM |
| Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem | vijayendra | QnA (read only) | 2 | 14-01-2007 09:38 AM |
| Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? | sourav_digit | QnA (read only) | 3 | 27-12-2006 02:33 PM |
| Serius problem with my screen. Can u tell it s/w or hard ware problem . | tusarks | Hardware Q&A | 7 | 12-06-2006 01:58 PM |
| fedora cd iso problem(installation from hard drive problem) | harmax | Open Source | 3 | 01-07-2005 11:34 AM |
