Old 23-08-2007, 10:13 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
saket narayan's Avatar
Default Best Graphix Card for ASUS P5LD2-VM-CR-SI
Dear all,
My system has following configuration:
CPU: Intel Core 2 Duo E6300
Motherboard Chipset: Intel i945G/GZ
Motherboard Model: P5LD2-VM-CR-SI
I want to know which will be the best graphix card within Rs. 15k limit.
saket narayan is offline
Old 23-08-2007, 10:37 PM   #2 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Default Re: Best Graphix Card for ASUS P5LD2-VM-CR-SI
Originally Posted by saket narayan
Dear all,
Go for Geforce 7900GT,8600GTS or 8800GTS(320MB).If u can buy the 8800GTS 320MB(For Rs17000)then go for it.However i do not recommend in wasting ur money in older technology.However if ur shorter on budget u can go for 7900GT(Rs 14000)
Harvik780 is offline
Old 23-08-2007, 11:00 PM   #3 (permalink)
My smps is of 250W. Will it be able to take load of 8800GTS(320MB) which is a higher end card. It must be taking a lot of power? If my smps really needs an upgradation, which one will be suitable for this config.?
One more thing...is 7950 GT better than 7900GT??
Old 23-08-2007, 11:17 PM   #4 (permalink)
Google Bot
Pathik's Avatar
get a 8800gts 320mb.. 16.x k..
Pathik is offline
Old 24-08-2007, 09:11 AM   #5 (permalink)
tech mighty
arun_chennai's Avatar
250W SMPS can't handle any graphics card....
so get 8800Gts and also a PSU.....
arun_chennai is offline
Old 24-08-2007, 09:42 AM   #6 (permalink)
dOm1naTOr's Avatar
@saket narayan
yes 7950GT is better than 7900GT.
And as of my knowledge, there are no 250w smps makers arounf here. Itll be 350..ok nyway it dun matter as it cannot handle the load
Gop for Power Safe, Colorsit or Zebronics Platinum 500w. All are around2k and can easily manage a 7900GT or 8800GTS 320.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 24-08-2007, 11:06 AM   #7 (permalink)
assasin's Avatar
dont be so sure.my HP 250W psu easily handles my rig which has a 8600GTS.havent faced any issues with it.
assasin is offline
Old 24-08-2007, 11:55 AM   #8 (permalink)
Phalanx's Avatar
If i remember correctly u had a 8600GT a few days back...Am jus curious y u did this incremental upgrade???
C2D E4300, MSI P6N SLI Platinum, Transcend 2GB 667MHz, XFX 8600GT, Viewsonic VG1930wm, Seagate 250GB SATAII, Lite-On LH-20A1P, Compro VideoMate X50, Microsoft wireless KB and Mouse, iBall Grabit.....
Phalanx is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/66373-best-graphix-card-asus-p5ld2-vm-cr-si.html
Best Graphix Card for ASUS P5LD2 VM CR SI Hardware Troubleshooting Question This thread Refback 01-01-2011 10:39 PM
asus p5ld2-vm or p5ld2vm se?? azad Hardware Q&A 2 23-02-2007 08:05 PM
Help Re:Graphix card and Motherboad. REY619 Hardware Q&A 4 14-10-2006 08:01 AM
Asus P5LD2-Vm not available so now which? abyssman Hardware Q&A 2 08-06-2006 03:20 PM
