Old 22-08-2007, 05:51 PM   #1 (permalink)
Default Help with motherboard **URGENT**
I have selected ASUS P5B Deluxe as my new Motherboard. While going through it's specificatons I found this
-Support Intel® next generation 45nm multi-core CPU
- Intel LGA775 Platform
- Intel® Quad-core CPU Ready
- Intel® Core™2 Extreme / Core™2 Duo Ready
- Intel® Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Ready
But at the bottom..it is written
Compatible with all FSB1333/1066/800/533MHz CPUs except Quad Core..
What does it mean...I am confused...
Please help.. it's urgent..
Thank You
Link to Asus
vineetrocks2005 is offline
Old 22-08-2007, 06:05 PM   #2 (permalink)
Deadman Walking
Batistabomb's Avatar
Default Re: Help with motherboard **URGENT**
Dude why are you still thinking to buy that it supports all excellent gaming,in all of the recent motherboards supports SMP(2 processors) and quad core is the ability of 4 processors in one chip which was next generation,also quad core is still in labs,nowadays all are using core2 duo or dual core where your motherboard supports those features
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 22-08-2007, 06:16 PM   #3 (permalink)
Google Bot
Pathik's Avatar
Rather get a P5K deluxe..
If you want a cheap board then get a xfx 650i ultra or Asus p5k e
Pathik is offline
Old 22-08-2007, 06:29 PM   #4 (permalink)
I have read some good reviews abt P5B DLX Mobo.... that's why I have selected it...& I can't go for P5K DLX as it is too expensive (abt Rs.16000 in my city)... It will shake my budget...
Old 22-08-2007, 08:28 PM   #5 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Post ur problem here at the asus technical query section.It'll be worth it
http://vip.asus.com/eservice/techser...Language=en-us
U'll get all ur answers here.
Harvik780 is offline
Old 23-08-2007, 03:31 PM   #6 (permalink)
Phalanx's Avatar
Which graphics card do you plan to use? Coz P5B supports Crossfire and not SLI...So if u want to use multi GPU in the future, you have to get 2 ATI cards... In case you buy an nVidia card now, you will have to chuck it whenever you decide to go for multi-gpu gaming... And in graphic card nVidia rules big time in India...So think about it... And if you do not plan to use multiple gpus for a long long time, then there is no use paying a premium for getting dual PCI-e slots... Better go for an NForce 650i Ultra mobo in that case...
And as far as your query is concerned, well P5B does support Q Core http://in.asus.com/products.aspx?l1=...95&modelmenu=1
Happy Buying
P.S. --- Did you check out Asus P5N32-E Sli Mobo???
Thank You
Link to Asus
Just saw the link you have provided. After seeing that I think ASUS loves India, thats why only the Indian Version has Quad Core support
C2D E4300, MSI P6N SLI Platinum, Transcend 2GB 667MHz, XFX 8600GT, Viewsonic VG1930wm, Seagate 250GB SATAII, Lite-On LH-20A1P, Compro VideoMate X50, Microsoft wireless KB and Mouse, iBall Grabit.....
Phalanx is offline
Old 23-08-2007, 05:31 PM   #7 (permalink)
a.k.a Niks
Sylar's Avatar
Don't worry the P5B Deluxe supports the Quad Cores with the new BIOS update.. If u wanna be sure just go to ASUS CPU Support and check it out..
also i agree with 'pathiks'.. if u want a gr8 VFM mobo and ur budget is arnd 5-6k go for the XFX 650i Ultra.. It also OCs better...
Edit : Make sure if ur getting the Q6600 u get hold of the new Q6600 with G0 stepping and not the old B3 stepping...
huh? is it? i thought the whole world was using it!! Even i've got a Q6600 in my home...
.. E6750 2.66GHz|Asus P5W DH D'lux|2x1GB Kingston 667MHz|XFX 6800GS 512MB OC|Seagate 7200.10 320+250+250GB|Sony DRU-830A|Coolermaster 600W|Creative 5.1 T6060|Logitech EX111+G5|ASUS VW192T|Antec 900 ..
Sylar is offline
Old 23-08-2007, 06:30 PM   #8 (permalink)
assasin's Avatar
i think he was speakin bout the native quad cores.
assasin is offline
Old 23-08-2007, 07:11 PM   #9 (permalink)
Phalanx's Avatar
I dont think so...Coz he is confused about the text in the ASUS site which says
AND
at the same time!!!
Phalanx is offline
Old 24-08-2007, 06:37 AM   #10 (permalink)
Hey...what are native quad cores...?
Old 24-08-2007, 07:48 AM   #11 (permalink)
a.k.a Niks
Sylar's Avatar
well if he meant that, then i stand corrected..
Well current Intel Quad Cores are not real quads in the sense that they have 2 processor dies with 2 cores on a single die, sumthing like 2 core2duos put together (a core2duo has 2 cores on one die).. So when one core needs to communicate(exchange data in parallel computations) with another core on the other die it needs to use the cpu fsb thus making the bus busy...
Real quad cores or Native quad cores will be the ones where all the 4 cores will be on a single die, which AMD is planning to bring with its Quad Opterons...
Sylar is offline
Old 26-08-2007, 12:01 PM   #12 (permalink)
Is Intel C2D E6750 supported on ASUS P5B DLX Motherboard ??
please help...it's urgent
Last edited by vineetrocks2005; 26-08-2007 at 12:01 PM. Reason: Automerged Doublepost
Old 26-08-2007, 02:02 PM   #13 (permalink)
a.k.a Niks
Sylar's Avatar
^^ yup.. with the 1215 bios update... http://support.asus.com/cpusupport/cpusupport.aspx
Sylar is offline
Old 26-08-2007, 06:25 PM   #14 (permalink)
Is it possible to update BIOS without installing any kind of OS.... ??
Old 26-08-2007, 06:31 PM   #15 (permalink)
Google Bot
Pathik's Avatar
^^ yup
Pathik is offline
Old 26-08-2007, 06:41 PM   #16 (permalink)
that means we can update the BIOS using Floppy or USB Drive...OS is not necessary...
Old 27-08-2007, 08:05 AM   #17 (permalink)
But will a 1333 proccy even boot up with the XFX650i(though at 1066),or is an older proccy reqd to boot up and then flash the bios and then revert to the e6x50?
sashijoseph is offline
Old 27-08-2007, 12:02 PM   #18 (permalink)
a.k.a Niks
Sylar's Avatar
yes, download the bios update frm the manufacturer's site onto a floppy and then use the dos utility to update the bios...
I think the xfx 650i ultra supports 1333MHz FSB out of the box.. http://www.xfxforce.com/web/product/...oductId=989811
Sylar is offline
Old 27-08-2007, 12:03 PM   #19 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
hey suggest me a mobo too please
http://www.thinkdigit.com/forum/showthread.php?t=66596
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 01-09-2007, 10:04 AM   #20 (permalink)
Captain Jack Sparrow
jacksparrow18's Avatar
Question Re: Help with motherboard **URGENT**
can u tell me which board is good?
asus p5bvm or xfx 650i ultra
Gaurav Chauhan
The only thing i like about the stones is that they come in my life,and when i cross them automatically they become milestones of my life!!!
jacksparrow18 is offline
Old 01-09-2007, 10:39 AM   #21 (permalink)
Google Bot
Pathik's Avatar
^^ p5b vm if u want onboard gfx... xfx 650i if u want better vfm and better OCing..
Pathik is offline
[Urgent] Which Motherboard? vijayts CPU / Motherboards 6 06-09-2006 11:18 PM
Urgent help needed to decide which motherboard to use....... jay4u CPU / Motherboards 5 31-08-2005 09:48 AM
Plzz Help Regarding Motherboard !!! Its Urgent !! rockthegod CPU / Motherboards 10 14-08-2005 05:48 PM
HELP..NEED....URGENT....MOTHERBOARD...! DO or DIE SITUATION ragsbava CPU / Motherboards 6 18-07-2005 09:09 AM
Motherboard - Urgent help parimal_xp2003 CPU / Motherboards 6 24-06-2005 11:34 AM
