i m Ankush Gupta i have intel845 GVSR Mother board now days it show many problem like restarting,hanging,no display but when i loose the clips of processes fan it work well help what will i do and tell me is it the problem of processes or mother board
But first do what Pathiks suggested.Remove heatsink,apply some good thermal paste,put the HSF back on and properly.
And for heaven's sake don't "loose the clips" of your hsf else you'll let your processor's magic smoke out and as the saying goes..every electronic component works because of smoke trapped inside it;once the smoke is let out the part ceases to function.
But before doing all this you may want to check the cpu temp. in the BIOS or through software like Everest etc.Only if found abnormally high(or after removing the HSF),would you need to reapply thermal paste.
