Old 20-08-2007, 02:41 PM   #1 (permalink)
adit_sen's Avatar
Default Home Networking: I need help
I neet to set up a network at home, and I need help on how to go about it.
Here's my setup. I have two laptops and one desktop. I have an internet connection coming via a LAN cable, which I use occassionally. I also have a wireless connection (shared from my friend's router). And finally, I also use my mobile phone at times to connect to the net. Now I want to connect the three together to share files and also share the internet connection.
How would I go about this? Should I get a router (I prefer a wireless router)? or a hub? or an access point? and how would I share the internet connection between the three?
Cheers
AMD 4400+ X2; Compaq Presario M2202TU; Dell Inspirion 500m; Windows Vista Ultimate
adit_sen is offline
Old 22-08-2007, 01:46 PM   #2 (permalink)
adit_sen's Avatar
Default Re: Home Networking: I need help
no one?
adit_sen is offline
Old 22-08-2007, 02:08 PM   #3 (permalink)
Multicore Mutant
You can connect all three via bluetooth, if distance is not too much. Or u might use a hub, get three patch cords and share one of the Lancard (through ICS) to rest of the two laptops.
Gotta go now.
Hackattack is offline
Old 22-08-2007, 02:40 PM   #4 (permalink)
I'm back!
Bluetooth is gonna be slow for file transfers.
Instead of getting a hub, cables and then ending up with no mobility get a WiFi adapter for your desktop. Assuming that your laptops must already be having WiFi, once put on the same wireless network you'll have a truly mobile home networking experience.
Use Bluetooth to connect your cellphone to your laptops which most likely will have it built-in. To transfer files from cell to PC use a Bluetooth dongle or transfer files to laptop first and then to PC over WiFi.
Little Knowledge is Dangerous but a lot of Ignorance is just as Bad!
Minimalistix is offline
Home Networking Tips reqd. gg_3000 Hardware Q&A 8 07-05-2007 11:19 AM
Want to set up a wireless Home Networking. virus_killer Networking 4 20-04-2007 09:35 AM
Home Wi-Fi networking??? curvenger Hardware Q&A 5 20-02-2006 03:45 PM
networking two windows xp home computers prawin Networking 3 18-05-2005 10:44 AM
Wi-Fi Home Networking? imcool Tutorials 4 18-03-2005 08:25 PM
