well guys, i am getting a new system with a q6600 & a 8800GTX. I've decided to go with 800Mhz DDR2 RAM. The options open to me are Transcend and Zion. Which one should i go for??
My dealer says that zion is better (also more expensive)
but transcend is a major RAM manufacturer......i dunno which one to get!
Thanks in advance
Thanks in advance
If u are going for asus mobo then check out the Qualified Vedors list for supported ram types for ur mobo.Some rams which though meet the standard might even not allow the mobo to boot up or even cause stability issues,this is mainly seen in mobos which have the 680i chipset.
