Old 20-08-2007, 01:08 AM   #1 (permalink)
9437077259
go4saket's Avatar
Default Core2Duo or Core2Quad???
Hi guys!
I want to buy a new desktop and am really confused in a few matters. I am sure you guys can help me out with it. Although the list of my doubts is some what long, but please try to help me as much as possible.
  1. What is the basic difference between C2D & C2Q. As I am not much into multitasking, should I go for a C2D or C2Q. I generally do one thing at a time and here is C2Q going to give better performance than C2D. Please also provide me with some links where in I can learn a bit more about the difference between C2Q & C2D.
  2. I saw that Intel Q6600 is 2.8 GHz. Does this mean that all four cores have a speed of 2.8 Ghz. or is it the total of all four.
  3. How does a higher L2 Cache help in a computers performance.
  4. I heard that Intel is soon going to launch 45nm processors against the present 65nm. Does this "nm" part has any effect in the overall speed of the machine or is it just for voltage. Moreover, should I wait for the new 45nm or is it ok to go for 65nm.
  5. Now the most important one, should it be Intel or AMD. Whichever it may be, please also mention the model of the processor and if possible, a good motherboard also for the same.
Thanks in advance...
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 20-08-2007, 01:13 AM   #2 (permalink)
Help~Is~Here's Avatar
Default Re: Core2Duo or Core2Quad???
Before answering all those questions, if you can wait for like 2~3 months, then I would advise you to wait, because there is a whole new batch of processors and chipsets coming out from both AMD and Intel stables.
Help~Is~Here is offline
Old 20-08-2007, 01:28 AM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
Originally Posted by go4saket
[*]What is the basic difference between C2D & C2Q. As I am not much into multitasking, should I go for a C2D or C2Q. I generally do one thing at a time and here is C2Q going to give better performance than C2D. Please also provide me with some links where in I can learn a bit more about the difference between C2Q & C2D.
basic difference is the no. of cores. pluz each core has its own cache. so more cache.. more perf.
[*]I saw that Intel Q6600 is 2.8 GHz. Does this mean that all four cores have a speed of 2.8 Ghz. or is it the total of all four.
each core operates at that speed.
[*]How does a higher L2 Cache help in a computers performance.
cache is like a bridge between the main memory and the proc core. so more the better. plus cache works at a higher speed than ram (almost the speed of the proc. and hence faster)
[*]I heard that Intel is soon going to launch 45nm processors against the present 65nm. Does this "nm" part has any effect in the overall speed of the machine or is it just for voltage. Moreover, should I wait for the new 45nm or is it ok to go for 65nm.
that diff. in the fabrication is mostly aimed at lowering the power consumption and hence the heat dissipation. however, theoretically it helps in putting in more electronic components in the same region.
[*]Now the most important one, should it be Intel or AMD.
it all depends on ur budget. on the lower end side (for a low budge system) i'd recommend amd while if u are ready to spend moderate amount i'd suggest the core2 line of cpus.
infra_red_dude is offline
Old 20-08-2007, 01:57 AM   #4 (permalink)
CG Artist
gaurav_indian's Avatar
Is C2Q available in India?
gaurav_indian is offline
Old 20-08-2007, 02:39 AM   #5 (permalink)
^^ Com'on man, don't tell me you don't know the answer to that. If not, yes Q6600 is available.
Basic difference is 2 core and 4 cores for the C2D and C2Q respectively. Since you are not going to do much multitasking and neither are you going to see a huge performance boost in everyday applications with the C2Q, you can safely go for the C2D series. No, if you are not multitasking or running processor intensive applications like video encoding/decoding, you are never going to see a performance difference.
http://en.wikipedia.org/wiki/Intel_Core_2
Four cores run at 2.8GHz, but it doesn't mean you are going to get 4x2.8GHz performance. You can think of it like a battery connected in 'parellel', it's still going to output the same volatage even if you increase the total no. of batteries although the batteries have individual similar charges.
The CPU cache is hitting serious problems with application performance however, as of now, the more the cache, the more the performance. Cache is like a storage next to your CPU core which means that your CPU doesn't have to wait for the data to be collected from the memory in which case it will have to wait for several hundred cycles as memory latencies are everincreasing. So, cache provides a quick accessible backup to the processor of all the commonly used functions by your CPU core. All older less regularly used functions are going to be sent back to the main memory because you don't have more than 4MB cache taking the case of a C2D.
http://en.wikipedia.org/wiki/CPU_cache
Well, it's basically going to make the chip smaller and cheaper, because the tinier the manufacturing process gets, the more no. of chips Intel can put on a single wafer of silicon. It is going to bring a difference in the temps and voltage sometimes but not in speed unless they are manufacturing a new model processor.
http://www.intel.com/technology/sili...technology.htm
Well, like I said first, it's better you wait another 2~3 months and by then a huge array of new processors will be released and a lot of dust will settle down making things clearer.
Last edited by Help~Is~Here; 20-08-2007 at 02:39 AM. Reason: Automerged Doublepost
Old 20-08-2007, 03:34 PM   #6 (permalink)
checkout:
deltapage.com
computerwarehousepricelist.com (download the xls file at top right corner)
Hey one question Quad core 2.66Ghz is priced at 12k, so is it worth to go for quad core considering its price.
Faun is offline
Old 20-08-2007, 03:52 PM   #7 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Originally Posted by T159
checkout:
deltapage.com
I read at the nvidia forums that currently core2quad wont give performance boost in games,but one should never believe what one says.I suggest u wait as the intel site suggests that core2quad processor available currently only support 1066MHz fsb.New line of quad core processors are coming out soon with 45nm fabrication and will support 1333MHz FSB.Anandtech has given info on the new line of processors from Intel and Amd.Also if u overclock the core2quad 6600 then u can easily leach out performance of ur 800Mhz DDR2 ram in Dual channel.
Harvik780 is offline
Old 20-08-2007, 05:28 PM   #8 (permalink)
The Quad Core processor from intel is not realy "Quad Core". It's just 2 C2D processors combined together. So, if one of the C2D needs to talk to the other C2D, it needs to come out of the CPU core, get onto the FSB and then go back into the other C2D, this not only eats up your FSB but also decreases the performance of what a qaud core should really be. As soon as Intel releases the true Quad core on a single chip, then you can consider going for that. Because the C2Q as of now are like the fake Dual core Pentium D processors that Intel sold. Intel infact is so good at marketing that it even makes virtual cores appear as real physical cores to the customer! So, don't go with the hype of "Quad Core" when it is not really a true Quad core. I would suggest either you wait for intel to come out with true Quads or wait till AMD brings out theirs. AMD on the other hand has never tried to fool the consumer. When it calls it processor a dual core, it really is a dual core. And AMD was the first one to bring out true dual core procs, and they are going to be the first ones to bring out true quad cores. I'm quite sure once the Quad AMD procs get released this september, they will beat the sh** out of the C2Qs like the X2's bet the sh** out of the Pentium Ds.
Don't tell me that you are not aware that it's been atleast a month since Intel released the 1333MHz G0 stepping Q6600 procs. And yes, it is already available in India but tough to find as most of them just want to finish the existing stock of 1066MHz B3 stepping Q6600s
Old 20-08-2007, 07:49 PM   #9 (permalink)
Techie By Heart
mavihs's Avatar
Post Re: Core2Duo or Core2Quad???
Originally Posted by Help~Is~Here
A I'm quite sure once the Quad AMD procs get released this september, they will beat the sh** out of the C2Qs like the X2's bet the sh** out of the Pentium Ds.
Till when r they going to release it in India???
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline
Old 20-08-2007, 08:13 PM   #10 (permalink)
The Transcendental
True. Don't trust either AMD or Intel though.
Wait till October (November in India) for the Penryn. They are also going to launch new mid range C2Ds like E4600. Then the E300, E4400 prices will drop by a grand and hopefully we also get true quads. Don't know how the Penryn's will OC though, since the smaller fabrication process makes them all the more sensitive to heat, so heat dissipation / proper cooling should have to be a priority if you OC.
I'll wait till the second batch of Penryns have settled down and we know of their abilities. Go for the E4600 though, if you can't wait longer.
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 20-08-2007, 08:15 PM   #11 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Exclamation Re: Core2Duo or Core2Quad???
man is it gonna be for real??i mean i've not heard of amd getting new procs out..maybe i was sleeping..do u have a link??
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 20-08-2007, 08:25 PM   #12 (permalink)
Well, their global launch I guess is set to be somewhere close to September 12th. So, I guess it should be available with your local dealer around september end. But not sure whether they are going to delay the launch again like they have been doing all along.
However, as far as Quad Cores are concerned, I wouldn't at all recommend anyone going for the Quad Core procs as of now, because honestly, there is hardly any software available that could use the full potential of the procs. So, all you can really do is keep overclocking these hardware and satisfy yourself by the numbers that you see when you benchmark these processors. As of now, these processors are nothing more than a hobbyist hardware. There is nothing in it for the laymen. Please don't come back and argue about the performance difference. All you seriously get is a <5~7 percent increase in performance for current day applications and that is seriously not worth for the layman.
So, till sofwares can acutally catchup with present day hardware, stick to the normal low priced processors you can get. i.e Unless you want to show off to everyone that you have a C2D or a C2Q by throwing additional amount of money for something that you are really not going to use. Hell, even a 2.8HT would do everything a C2D or C2Q can do, the only difference is the negligle performance difference for a layman althtough those numbers might make a lot of difference to enthusiasts.
http://www.google.co.in/search?hl=en...quad+core&meta=
And this link will show you the difference between AMD Quad and Intel Quad
http://multicore.amd.com/us-en/quadcore/
I must remind everyone that AMD is just releasing it's server processors in September. The desktop processors are expected to be released about within 15~30 days from the launch of the server opteron processors.
Last edited by Help~Is~Here; 20-08-2007 at 08:25 PM. Reason: Automerged Doublepost
Old 20-08-2007, 08:39 PM   #13 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
No i was following the intel site.I wonder what's the cost of the q6600 go stepping 1333Mhz processor.I'll upgrade the processor and GPU in next year july.And is the penryn been released and is it being made by 45nm process.This was what i was talking about,i didn't mention it cause of its weired pronunciation.
Here's the link i followed-
http://www.anandtech.com/cpuchipsets...spx?i=2972&p=1
Old 20-08-2007, 08:54 PM   #14 (permalink)
13.5K to 14K.
You have already decided to wait till july next year?? GOD alone knows what new technology will be available then which will leave us all confused whether to upgrade or not. I wouldn't suggest such long waiting periods to upgrade unless you did one recently
Old 20-08-2007, 08:57 PM   #15 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Old 20-08-2007, 09:06 PM   #16 (permalink)
Nope, it's not released. It's expected in November. This has nothing to do with the Q6600 G0 with 1333MHz. The Q6600 G0 stepping as I mentioned before is already available and it's manufactured with the existing 65nm process.
Old 21-08-2007, 10:44 AM   #17 (permalink)
9437077259
go4saket's Avatar
Is Penryn or the new processors with 45nm be cheaper than the C2D or C2Q...
Win 7 Ultimate
go4saket is offline
Old 21-08-2007, 01:05 PM   #18 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
As told by @help is here it has not been released yet,so u'll have to wait and watch.
Old 21-08-2007, 05:03 PM   #19 (permalink)
Like mentioned before, it not yet released, however, smaller nm manufacturing certainly means lesser price. It's because in the 45nm process, you can put more no. of chips on a single piece of silicon, which ideally means more processors for lesser price. Hence it should pass onto the consumers but don't expect a huge price cut, the price drops if any will be a negligble amount. Take for example the case of the XBox360. When microsoft started manufacturing the 45nm chips, the price for them meant that now they could manufacture 2 chips at the price of one, however, the actual benefit that was passed on to the customer was no more than $30~$50 reduction. It will take some time for companies to pass on the benefit completely to the end user.
Old 21-08-2007, 11:01 PM   #20 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Core2Quad
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 21-08-2007, 11:12 PM   #21 (permalink)
CG Artist
It seems Help_is_here is a Core 2 series dealer.
@nightmare tere avatar ki
Old 22-08-2007, 12:17 AM   #22 (permalink)
lol... I always support the underdogs in majority of the cases. I don't like the dominators of anything in any industry because they are there by doing lot of unethical business. Hence I always support the underdogs.
In the processor Industry, I support AMD than Intel
In the F1 industry, I support every other team other than Ferrari
In the software Industry I support anything that is not windows/Microsoft
If kenya and India are playing, I support kenya..
So on and so forth.. I always like the underdogs because they always keep fighting with the true spirit, not like the one's at the top of the list who use any means necessary to reach and stay there whether that be ethical or unethical
So, conclusion is: I am certainly not an Intel dealer
Old 22-08-2007, 12:30 AM   #23 (permalink)
CG Artist
^^ Digit or PC World?
Old 23-08-2007, 10:05 PM   #24 (permalink)
^^ heheheheh . . good one .
sagargv is offline
Old 24-08-2007, 12:51 AM   #25 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
bhai tum logo jab kuch nai melta to mere avatar k peche lag jate iss bar ki digit page 15 meri photo nikli hai bus location wrong di hai batao main uss me se kaun hu
Dell 15z + WD 2TB
iPhone 4 32 GB
Old 24-08-2007, 01:18 AM   #26 (permalink)
I haven't got my hands on a regular subscription of PCWorld so can't really say
Anyways, where's the guy who started this thread? What has he decided? Which one is he going to buy or did we all get him more confused??
Old 24-08-2007, 12:35 PM   #27 (permalink)
9437077259
go4saket's Avatar
Actually am thinking to wait for some time as some of you recommended and lets see how Penryn turns out to be both in terms of performance and cost effectiveness... Anyways, thanks a lot to all you guys for all this help...
Win 7 Ultimate
go4saket is offline
Old 24-08-2007, 12:44 PM   #28 (permalink)
left this forum longback
praka123's Avatar
Red face Re: Core2Duo or Core2Quad???
kaun si?guess ur young so ur Rohit Patel?
praka123 is offline
Old 24-08-2007, 04:42 PM   #29 (permalink)
Go with dual core instead of quad core. It is much lower priced than quad core and also as you are not really into multitasking it will be waste to buy a quad core cpu and not using it
Anyone who has never made a mistake has never tried anything new
sandeepk is offline
Old 26-08-2007, 03:30 AM   #30 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
anurag pandey
Dell 15z + WD 2TB
iPhone 4 32 GB
problem with core2duo ayush_chh Hardware Q&A 14 16-03-2007 08:48 PM
Core2Duo 3.0 Ghz Poll sourishzzz1234 Hardware Q&A 12 24-01-2007 01:32 AM
core2duo comp. for 25k- !!!! jz2linkinpark Hardware Q&A 7 31-08-2006 05:39 PM
want to buy core2duo with 965motherboard!! h_phalak Hardware Q&A 16 30-08-2006 05:39 PM
