Old 18-08-2007, 01:22 PM   #1 (permalink)
antoniobc's Avatar
Unhappy Any way to REPAIR RAM?
Have 2 SD RAM DIMMS. They both give the long beep sound when the comp starts up. Have tried rubbing the gold pins with an eraser and used Spirit to clean em but no luck.
Can anyone help me?
-- The Phoenix
antoniobc is offline
Old 18-08-2007, 01:33 PM   #2 (permalink)
shantanu's Avatar
Default Re: Any way to REPAIR RAM?
your RAM seems to be dead.. the only way is to change them...
shantanu is offline
Old 18-08-2007, 04:05 PM   #3 (permalink)
Norms Buster
RAM can never be repaired. Just replace !
VexByte is offline
Old 19-08-2007, 03:22 PM   #4 (permalink)
antoniobc's Avatar
Wink Re: Any way to REPAIR RAM?
Common guys? There must be something that a little tinkering can fix?
-- The Phoenix
Old 19-08-2007, 07:06 PM   #5 (permalink)
slugger's Avatar
sin c u insist
favorable result NOT guaranteed
How To Repair RAM
slugger is offline
Old 19-08-2007, 08:15 PM   #6 (permalink)
Cool and Calm
abhi_10_20's Avatar
RAM giving a beep sound????? so wierd
When Roger's at play, opponents pray..!!!!! :twisted:
abhi_10_20 is offline
Old 19-08-2007, 09:29 PM   #7 (permalink)
assasin's Avatar
clean the ram slots and try the ram in another pc.
assasin is offline
Repair Yum saurabh.sauron Open Source 2 07-02-2007 09:30 AM
Zip repair? navisangha QnA (read only) 4 22-07-2006 04:52 PM
Bad Cd Repair Pro V4.0 rajat22 QnA (read only) 4 24-10-2005 12:21 PM
XP TCP/IP Repair Curious Guest QnA (read only) 3 23-05-2005 06:27 PM
repair w2k ax3 QnA (read only) 4 12-12-2004 02:38 PM
