Old 17-08-2007, 05:33 PM   #1 (permalink)
Treatment in progress...
mukherjee's Avatar
Default Virtualizers
Well,people...can someone tell me about software virtualizers available for windows xp sp2 and their ease of use.
has anybody used it?which one?hows the performance?
i want to use it for surfing net actually..getting a lot of spyware and trojan attacks these days,thought of solving the problem once and for all.
my config:
e6420
xfx 650i ultra
2gb ram
xfx 8600gt
300gb sata2 hdd
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
Photography: Nikon D5100||Nikon 55-300 VRII
Canon Powershot SX220HS||Tamrac Velocity 9x
Audio Gear: Brainwavz M4||Meelec A151|| EP630
PX100 II||Fiio E5||AudioTechnica ATH-T500
mukherjee is offline
Old 17-08-2007, 06:19 PM   #2 (permalink)
a_k_s_h_a_y's Avatar
Default Re: Virtualizers
virtual box !!! u mean to run linux or windows right ?? in a virtual computer ??
http://www.virtualbox.org
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 17-08-2007, 06:32 PM   #3 (permalink)
This months Chip Magazine had listed three free Virtual OS Management software... Check it out... If possible, I will post info on that later...
Arun
sakumar79 is offline
Old 17-08-2007, 06:43 PM   #4 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
use vmware , it is da best
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 17-08-2007, 07:24 PM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
VMWare wokrs good but its paid, and I felt some what Resource hungry...
Microsoft Virtual PC 2007, is a free product and works good on my Windows system, but one big problem is it doesnt run well with Linux !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 17-08-2007, 08:21 PM   #6 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
MVPC 2k7... kool... but i had a prob... my WinXP installation as os in the virtual pc... had a prob accessing my harddisk as shared folder. It always hangs up... so i'm not able to access my actual hard disk in this virtual pc!!! I tried using shared folder method.. it shows as network folder.. but as soon as i access the drive.. it stops working & hangs up.... choto... anand.. other mvps... any replies..
koolbluez is offline
Old 17-08-2007, 08:36 PM   #7 (permalink)
Rebooting
Well Share the Host systems Drives with Full read write access 1st...
Now Install the Virtual PC Tools... inside the Virtual PC OS...
Change the VPC Network to LAN Only !!! So that you can asign Separate IP Address for that Guest OS...
Now just follow basic Home Networking as u would have done with 2 cross cable connected PC thats it
rebooting
ChotoCheeta.com
Old 17-08-2007, 08:47 PM   #8 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
After that.. it's somewhat unrealated greek&latin to me... me being poor in networking fine points.
I am supposed to be able to access the folder directly without any probs after the installation of VPC tools... why this networkin adjustments...
Old 17-08-2007, 09:06 PM   #9 (permalink)
Rebooting
Well My frnd, VPC Tools installation does couple of things, like making Mouse and Media Playing smoth, and its allows you drag and drop, means Start the VPC OS, and drag any file from the Backgroup Windows Explorer to VPC Desktop it will copy it self...
but that doesnt allow the avance networking setup u want like Browsing your Host OS File structure from Guest OS...
For that you need to setup one small home PC to PC network...
rebooting
ChotoCheeta.com
Old 17-08-2007, 09:13 PM   #10 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
.. now i'm begining to hate the concept... tryin... tnx..
Old 18-08-2007, 05:26 PM   #11 (permalink)
mukherjee's Avatar
Yeah rite..but hw to use and configure it??
well,i wont use linux..jus plain a guest winxp sp2 setup for net surfing.ne tips on how to do that?
one more thing..i have bsnl broadband connection....how to use that from within the virtual os(guest os)?
Old 18-08-2007, 07:14 PM   #12 (permalink)
arrey yaar its easy ! in virutal box...i dunno abt VM WARE coz its paid and i dont care abt it !
just click new and follow instructions allow 512 MB Usage !!
and some 4 GB space in some drive !!
start your virtual machine
mount DVD R/W using the option in Machine option !! put a bootable DVD
it boots thru it !! install !!
it between during installation of linux will say " this might erase your entire hard disk "
dont worry it will erase your Virtual harddisk in the virtual machine !! lolzz !! not your real physical hard disk !!
i hope i helped !
Old 18-08-2007, 09:09 PM   #13 (permalink)
Rebooting
@mukherjee
Thats very simple...
use this option is settings of VMware instalaltion of Windows XP... at Settings go to Network, there use option NAT for Network
Edit : Pic Removed
this will allow VPC OS to directly access Internet as a application under Host OS
rebooting
ChotoCheeta.com
Old 19-08-2007, 12:23 AM   #14 (permalink)
mukherjee's Avatar
@mukherjee
Thanks choto.
but i wont be using vmware!! either Virtualbox or Microsoft Virtual PC 2007.How to share BSNL Broadband internet connctn in them?Plz tell....neone!!
BTW,which virtualizer do u use and for wat?
i hope i helped !
hmm.thanks.but i wont be using linux bro.jus win xp.wat will i do for dat?
and nodr ques:i have BSNL broadband.How do i use it in the virtual machine?Plz elaborate on it...
Old 19-08-2007, 12:26 AM   #15 (permalink)
Rebooting
@mukherjee
Extremelly sorry...
I made one typos... its Microsoft Virtual PC I gave reference too... even the screen shot is from MS VPC...
Sorry for the mis-understanding....
Cheeta....
rebooting
ChotoCheeta.com
Old 19-08-2007, 12:43 AM   #16 (permalink)
mukherjee's Avatar
@mukherjee
Extremelly sorry...
Cheeta....
never mind bro..it happens..n i m a gr8 culprit in typos too...but that really got me stumped too!!!
Old 19-08-2007, 12:49 AM   #17 (permalink)
Rebooting
newys....wat abt the win xp sp3 thing i say on that window caption??
Testing it but I am not allowed to say any thing on that, MS NDA wont allow me... removing that PIC
rebooting
ChotoCheeta.com
Old 21-08-2007, 10:10 PM   #18 (permalink)
mukherjee's Avatar
@ choto
hey i installed ms vm 2007 and have winxp sp'2' running..but i cant get the network to work.cant surf the net ffrom guest pc.wat can i do?plz guide.
Old 21-08-2007, 10:43 PM   #19 (permalink)
^ have u installed virtual machine additions ? if not , do it . boot the guest OS ( winxpsp2) in vm . capture iso image . in the program files\microsoft virtual machine(watever , u got the point ) \ virtual machine additions . . install vm additions in ur guest OS in vm . goto settings > select ur network adaptor . it works for me .
sagargv is offline
Old 21-08-2007, 10:49 PM   #20 (permalink)
mukherjee's Avatar
okk will try it and update..thanks in advance..
Old 21-08-2007, 11:19 PM   #21 (permalink)
Rebooting
1st of all make sure u r connected to the Internet !!!!
now Go to Windows Firewall Settings or any 3rd party Firewall and Add Microsoft Virtual PC in its Exclusion list for all type of activities....
In my case its Windows Vista Firewall !!!
Now in VPC go tyo the Settings of the Guest OS, and then at its Network settings select the networking type as Shared Network (NAT)
Now u should be able to access internet from ur Virtual PC... as it will access the Internet from Host OS as a program !!!
rebooting
ChotoCheeta.com
Old 22-08-2007, 12:20 PM   #22 (permalink)
mukherjee's Avatar
oh no.still i cant..plz help me...
Old 22-08-2007, 04:05 PM   #23 (permalink)
Rebooting
Make sure no Firewall is enabled... !!!!
rebooting
ChotoCheeta.com
Old 22-08-2007, 05:06 PM   #24 (permalink)
try selecting the actual network adaptor u're using instead of shared networking in settings in virtual pc . do u have zone alarm or anything ?
sagargv is offline
Old 22-08-2007, 06:26 PM   #25 (permalink)
i hv a prob installling ubuntu in win vista in virtual box
its says can't create ext3 partition while installing why does this happen ?
- by kool
