Old 17-08-2007, 11:42 AM   #1 (permalink)
Default Symbian S60 Woes!
i own a nokia 6680. when i bot d mob a couple of years back evthin was wurkin fine. but now d hot swappable memory card function aint functionin. if i need 2 change d mem card i got2 switch off d cell wich is a tedious job. does ny1 knoe d reason? or mayb a format of d fon mem n change of os mit work? plese reply all s60 users!!!
~PunK~ is offline
Old 17-08-2007, 11:48 AM   #2 (permalink)
Pee into the Wind...
shady_inc's Avatar
Default Re: Symbian S60 Woes!
What's the exact problem with your memory card.??If the fone is just not detecting it,it may have become corrupt.You don't need to switch off the fone to take out the mem. card in 6680.
Life is as complicated as you say it is.
shady_inc is offline
Old 17-08-2007, 02:15 PM   #3 (permalink)
Thumbs up Re: Symbian S60 Woes!
first of all. thnk u!
but in all of ma frens 6680 d mem can b removed n changed while switched on ( hot swappable) n so is also mentioned in d manual. theres no such problem of corrupt card or nything. only thing is dat it fails 2 read ny other mem card aftr 1 has been removed n d mob is not switched off. once restarted evthin wurks f9.
once again thank u 4 ur reply.
i wud also like 2 know if changing d os will wurk? amean formattin ram n fon n getting s60 ver 6 on it.
Regards
~PunK~
~PunK~ is offline
Old 17-08-2007, 02:48 PM   #4 (permalink)
pushkaraj's Avatar
@punk, first of all, you are posting in the wrong section, bro. There is a section in this forum by the name Mobile Monsters. All your queries regarding mobile devices will be entertained there.
As far as your question is concerned, i would suggest you to format your memory card and check if it is then possible to hot swap it.
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 17-08-2007, 02:51 PM   #5 (permalink)
Noobie Pro
alsiladka's Avatar
You cannot upgrade the S60 version on any phone, the S60 OS is hardware dependant and is not upgradable.
You may be facing a virus problem or maybe due to some software installed, the phone is not able to make itself ready for the Mem card removal. I would suggest you scan the card for viruses on the computer, and try the Hot Swapping with any of your friends card.
You should also consider updating your phones software by visiting www.nokia.com/softwareupdater
If nothing works, take a backup off all your imp Data, not the softwares, just multimedia and contacs and sms. Format the Mem card using, and then format your phone using the code *#7370#
www.twitter.com/alsiladka
alsiladka is offline
Old 17-08-2007, 02:52 PM   #6 (permalink)
Google Bot
Pathik's Avatar
wat error do u get wen u try to hot swap..?? Also try formatting ur fone.. And u cant change its os
Pathik is offline
Old 17-08-2007, 10:43 PM   #7 (permalink)
hey pushkaraj, am sorry as i am new 2 dis forum...
nthin wurks as i maself own 3 mem cards n have tried a million times formatin..
now to pathiks query..
ders no error neither ny message shown as in my n70 wen i open d mem card door it shows cloasing all apps. dis mesg DOES NOT APPEAR on my 6680.
wat i meant by change of os is updating its version
THANX 2 ALL O'U 2 TAKE TYM N PROVIDE A SOLUTION!!!!
regrd
~PunK~
~PunK~ is offline
Old 17-08-2007, 11:35 PM   #8 (permalink)
shady_inc's Avatar
U can most certainly upgrade ur firmware version.Just visit the link alsiladka
provided.U NEED TO HAVE MORE THAN 512 MB RAM IN UR PC FOR THAT!!!
But I don't think that will help u much with ur mem. card woes.
You can try formatting the card and then hard-formatting the fone.You can do switching off your fone,as the fone powers on keep the "green call key"+ "*" + "3" pressed at same time.this will restore your fone to original settings.DO IT AT YOUR OWN RISK!!!
Old 17-08-2007, 11:47 PM   #9 (permalink)
pushkaraj's Avatar
Lightbulb Re: Symbian S60 Woes!
No problem, mate.
Then the problem is certainly with your phone. Just as others said, try formattin the phone after backup of important data and c if the problem gets solved.
Old 19-08-2007, 12:59 AM   #10 (permalink)
thanx a ton!! i've tried all d above mentioned solutions buh nthin seems 2 cleick!! nywayz i guess ill have 2 keep on switchin on n off weneva i wanna remove the card. lolz...
nywayz i earnestly thnk u ppl 4 ur efforts 2 help me!
REGARDS
~Peace Out~
~PunK~
~PunK~ is offline
Where can we get Symbian Codecs Pravas Mobiles and Tablets 8 13-03-2007 11:26 PM
Symbian app for recording FM? Cool G5 Mobiles and Tablets 3 18-02-2007 12:32 AM
Symbian OS sai_cool Mobiles and Tablets 7 04-08-2006 08:31 PM
Symbian???? freakanomics Mobiles and Tablets 31 04-07-2006 06:42 PM
iTunes\WMP for Symbian dIgItaL_BrAt Mobiles and Tablets 1 27-11-2005 11:39 PM
- by kool
