Old 16-08-2007, 01:21 PM   #1 (permalink)
Exclamation Need Advice!!!!!
I am having Pentium IV 2.8 HT Processor and 915 GAV Motherboard. I like to upgrade my motherboard as the said motherboard is making too much noises when i run any software or play game.
I am fond of games. So suggest me a good motherboard or any other idea. And dealer in Chandigarh which can provide the products.
function __RP_Callback_Helper(str, strCallbackEvent, splitSize, func){var event = null;if (strCallbackEvent){event = document.createEvent('Events');event.initEvent(str CallbackEvent, true, true);}if (str && str.length > 0){var splitList = str.split('|');var strCompare = str;if (splitList.length == splitSize)strCompare = splitList[splitSize-1];var pluginList = document.plugins;for (var count = 0; count < pluginList.length; count++){var sSrc = '';if (pluginList[count] && pluginList[count].src)sSrc = pluginList[count].src;if (strCompare.length >= sSrc.length){if (strCompare.indexOf(sSrc) != -1){func(str, count, pluginList, splitList);break;}}}}if (strCallbackEvent)document.body.dispatchEvent(even t);}function __RP_Coord_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Coord_Callback = str;pluginList[index].__RP_Coord_Callback_Left = splitList[0];pluginList[index].__RP_Coord_Callback_Top = splitList[1];pluginList[index].__RP_Coord_Callback_Right = splitList[2];pluginList[index].__RP_Coord_Callback_Bottom = splitList[3];};__RP_Callback_Helper(str, 'rp-js-coord-callback', 5, func);}function __RP_Url_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Url_Callback = str;pluginList[index].__RP_Url_Callback_Vid = splitList[0];pluginList[index].__RP_Url_Callback_Parent = splitList[1];};__RP_Callback_Helper(str, 'rp-js-url-callback', 3, func);}function __RP_TotalBytes_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_TotalBytes_Callback = str;pluginList[index].__RP_TotalBytes_Callback_Bytes = splitList[0];};__RP_Callback_Helper(str, null, 2, func);}function __RP_Connection_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Connection_Callback = str;pluginList[index].__RP_Connection_Callback_Url = splitList[0];};__RP_Callback_Helper(str, null, 2, func);}function __RP_Callback_Helper(str, strCallbackEvent, splitSize, func){var event = null;if (strCallbackEvent){event = document.createEvent('Events');event.initEvent(str CallbackEvent, true, true);}if (str && str.length > 0){var splitList = str.split('|');var strCompare = str;if (splitList.length == splitSize)strCompare = splitList[splitSize-1];var pluginList = document.plugins;for (var count = 0; count < pluginList.length; count++){var sSrc = '';if (pluginList[count] && pluginList[count].src)sSrc = pluginList[count].src;if (strCompare.length >= sSrc.length){if (strCompare.indexOf(sSrc) != -1){func(str, count, pluginList, splitList);break;}}}}if (strCallbackEvent)document.body.dispatchEvent(even t);}function __RP_Coord_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Coord_Callback = str;pluginList[index].__RP_Coord_Callback_Left = splitList[0];pluginList[index].__RP_Coord_Callback_Top = splitList[1];pluginList[index].__RP_Coord_Callback_Right = splitList[2];pluginList[index].__RP_Coord_Callback_Bottom = splitList[3];};__RP_Callback_Helper(str, 'rp-js-coord-callback', 5, func);}function __RP_Url_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Url_Callback = str;pluginList[index].__RP_Url_Callback_Vid = splitList[0];pluginList[index].__RP_Url_Callback_Parent = splitList[1];};__RP_Callback_Helper(str, 'rp-js-url-callback', 3, func);}function __RP_TotalBytes_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_TotalBytes_Callback = str;pluginList[index].__RP_TotalBytes_Callback_Bytes = splitList[0];};__RP_Callback_Helper(str, null, 2, func);}function __RP_Connection_Callback(str){var func = function(str, index, pluginList, splitList){pluginList[index].__RP_Connection_Callback = str;pluginList[index].__RP_Connection_Callback_Url = splitList[0];};__RP_Callback_Helper(str, null, 2, func);}
jatin931 is offline
Old 19-08-2007, 11:23 AM   #2 (permalink)
Default Re: Need Advice!!!!!
39 Views and no reply . Is there any technical person who can suggest me????
jatin931 is offline
Old 19-08-2007, 11:27 AM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
U missed this, http://www.thinkdigit.com/forum/showthread.php?t=63874
and its not Motherboard whoch makes noise... some thing else is making the noise, possible its the high speed LGA 775 Cooler fan !!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 23-08-2007, 03:58 PM   #4 (permalink)
The above thread don't have any suggestion for Pentium 2.8 HT Processor, And the sound is made by the processor fan........
jatin931 is offline
Old 23-08-2007, 04:49 PM   #5 (permalink)
slugger's Avatar
Originally Posted by jatin931
function __RP_Callback_Helper(str, strCallbackEvent, splitSize, func){var event = null;if (strCallbackEvent){event = document.createEvent('Events');event.initEvent(str CallbackEvent, true, true);}if (str && str.length > 0){var splitList = str.split('|');var strCompare =...........
ver did u copy-paste d thing from?
i dont thin its got ne thin 2 do with ur mobo suggestion
slugger is offline
Old 23-08-2007, 06:11 PM   #6 (permalink)
It's not your motherboard or the proccy fan's problem.It's probably due to soaring temperatures inside your cabinet.Keep one of the side panels of your cabinet open and then see if the noise reappears.Check proper airflow inside the cabinet.If not already present,attach extra cabinet fans.Monitor the temperatures using everest etc.
sashijoseph is offline
Old 23-08-2007, 06:19 PM   #7 (permalink)
a.k.a Niks
Sylar's Avatar
Wats ur budget like? we could surely suggest sumthing better then... For starters the XFX 650i Ultra for arnd 5.5k and the c2d E4400 for arnd 5.2k should be a good combo.. Or if u can accomodate go for the E6750 which is for arnd 8.4k (best VFM chip IMO)...
Huh.. btw it is the proccy fan which makes the noise when it runs at a higher rpm due to the higher temps of the processor.. and p4 stock HSFs are rather famed for the high noise they create.. so u cant rule out the fan and proccy as such...
.. E6750 2.66GHz|Asus P5W DH D'lux|2x1GB Kingston 667MHz|XFX 6800GS 512MB OC|Seagate 7200.10 320+250+250GB|Sony DRU-830A|Coolermaster 600W|Creative 5.1 T6060|Logitech EX111+G5|ASUS VW192T|Antec 900 ..
Sylar is offline
Old 23-08-2007, 09:02 PM   #8 (permalink)
Guess I put it wrongly...it is of course the HSF making the noise but the problem could lie elsewhere like poor cabby ventilation etc.Only if these are sorted out can we blame the HSF squarely.Ya and the stock HSF sux bigtime.
Old 24-08-2007, 12:07 AM   #9 (permalink)
"The Gentleman"
vish786's Avatar
sound can also be reduced by cleaning dust accumulated on fans, mobo, extra stuff.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 24-08-2007, 01:26 AM   #10 (permalink)
a.k.a Niks
Sylar's Avatar
^^ well yeah, that can be done.. but still y r u discouraging him frm upgrading , he wants to upgrade, help him with that... he's got a pretty old rig after all...
Sylar is offline
Old 25-08-2007, 12:58 PM   #11 (permalink)
Ya, I also don't know what the hell is this, I tried deleting it but no changes........
I have kept my Cabinet open from one side, but the problem arises....
jatin931 is offline
Old 25-08-2007, 01:01 PM   #12 (permalink)
You could try reapplying thermal paste on your processor and graphics card. There are tons of threads on other sites, where doing so has drastically dropped temperatures.
I recommend Arctic Silver 5 - please do read up on correct applying method before doing so.
sandys is offline
Old 25-08-2007, 01:03 PM   #13 (permalink)
And Another question :
Should I go for a good motherboard or decent motherboard with decent graphic card ??????
Thanks for the suggestion....
I hope this will work..
jatin931 is offline
Old 25-08-2007, 01:33 PM   #14 (permalink)
a.k.a Niks
Sylar's Avatar
if u want to use thermal paste, then Arctic Cooling MX-2 .. better than AS 5
Application Instructions
Sylar is offline
Old 25-08-2007, 06:37 PM   #15 (permalink)
jatin931 is offline
Old 25-08-2007, 06:45 PM   #16 (permalink)
M$™ Certified Spammer
entrana's Avatar
guys cud i ask what exactly does a thermal paste do and how u apply it
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 25-08-2007, 11:17 PM   #17 (permalink)
a.k.a Niks
Sylar's Avatar
@entrana .. check out my post above mate.. It clearly says Application Instructions, just click on the link !!!!
Btw application instructions for different brands of thermal paste may vary, so better check out the manufacturer's site first..
For more info.. http://reference.techpowerup.com/The..._How_to_use_it
Sylar is offline
advice hariharan QnA (read only) 2 14-01-2007 10:19 AM
Amd Advice pheonix CPU / Motherboards 14 20-06-2005 01:39 AM
An Advice maximus QnA (read only) 5 22-04-2005 11:22 AM
ADVICE ME PLZ.......... hareesh QnA (read only) 15 24-02-2005 07:01 PM
Your advice-reg. kumarn_2004 QnA (read only) 3 05-02-2005 05:19 PM
- by kool
