Old 16-08-2007, 12:11 AM   #1 (permalink)
Default multiple routers????
Well, this is sopmething unique.
I am using net VIA ADSL connection, and running my laptop and desktop machine through that.i.e separate cables from lappy and desktop connected to the ADSL router.
Yest i made a new arrangement:
I took another ADSL router and connected it to the present on e via a LAN cable. and then to that router i connected by laptop.
I was getting network on both the machines however i kept getting disconnected very often like once in 5 mins for about 1 min. also wheni checked on the local server sire, it said disconnected.
On reverting back to my default/original network setup, i stopped facing this problem.
COULD ANYBODY EXPLAIN ME THE REASON???
samaryaj is offline
Old 18-09-2007, 11:02 PM   #2 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
Default Re: multiple routers????
two routers cascaded will always create problem. You need to change the lan IP of second router. It should solve the issue.If it not solve the issue , let me know . I will try my level best to assist you.
n00b forever...
~Phenom~ is offline
Does anybody know any routers Forum ? imprince Networking 6 12-04-2008 09:03 PM
can v create one seperate portion for Routers and Switches Related discussion ? dadhwalprince Networking 3 16-07-2007 08:36 PM
Question regarding routers & ADSL modems borg Networking 3 15-08-2005 08:06 PM
- by kool
