Old 15-08-2007, 10:52 PM   #1 (permalink)
Default 8800 GTX Temperature !
hey guys
thanks to all o u and ur awesome advice, i bought my pc in april this year wiht an XFX 8800 gtx, e6400, OCZ 2 gig ram, samsung 205 bw 20", WD 320 GB, X-fi extreme audio..... and a cooler master 700 W PSU.... and an ASUS P5b n32 SLi premium mobo... evertyhitngs been running fine but i just installed nvidia ntune and its showin my GPU temp at 61 degrees celcius.... my system and cpu temps are fine around 30- 35..... i have 1 120 mm fan at the bak, one 60mm on the side, 2 60 mms in front and of course the stock CPU keatsink and fan and the fan on my GPU.... cant afford water cooling yet.... is there an effective cooling thing whihc i can use for my GPU..... coz the 8800 gtx is so huge that it barely leaves space fopr anything else.... i cud probably squeeze in a fan or sumthin though but is it really gonna be effective... ??
- Lost Planet Dx 9 demo...... 42 fps with everything on.... 1280*960 res. 16xAA......
rsingh is offline
Old 15-08-2007, 10:58 PM   #2 (permalink)
Default Re: 8800 GTX Temperature !
61C , well if its peak , then its damn low . . . its quite normal . .
sagargv is offline
Old 15-08-2007, 11:00 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
Temps are quite fine... Install one Few Caninet fan if possible... !!! that would help pull out the Worm air from in side the box !!!
but in any case temps are fine..
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 16-08-2007, 09:32 AM   #4 (permalink)
Hanging, since 2004..
tarey_g's Avatar
Temprature is just fine , my friends 8800 ultra is on 60-65 on normal operation. He got a server cabinet which is huge and weighs 15 Kilo and has plenty space inside to accomodate extra fans for the card/hdd or processor. If you can ad extra cooling in this cabinet ,then its fine. Else try a bigger cabinet.
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
tarey_g is online now
Old 16-08-2007, 07:25 PM   #5 (permalink)
thanks guys..... if thats the average temp tehn im happy.....
rsingh is offline
Old 17-08-2007, 10:07 AM   #6 (permalink)
Hells_Fury's Avatar
Is it the factory overclocked 8800 GTX? 61C is awesome even for stock settings, but for overclocked settings its mind-blowing!!!
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
Hells_Fury is offline
CPU temperature 99 deg risqer CPU / Motherboards 20 05-09-2007 12:55 PM
Is this temperature OK? phreak0ut Hardware Q&A 11 25-03-2007 02:31 PM
temperature chirayu garg QnA (read only) 2 07-06-2005 02:02 PM
Temperature Avtar9 QnA (read only) 5 13-09-2004 12:50 AM
- by kool
