Old 15-08-2007, 07:14 PM   #1 (permalink)
Good Boy
george101's Avatar
Exclamation Hard-disk tooooooooooo slowwwwwww
i just brought a seagate 250gb sataII harddisk. its toooo slow when i copy anything from or to it......... its takes almost half an hour to copy just 300mb. i already have a 160gb seagate harddisk and its very fast when compared to this. wat might be the problem guyss......... is it sumthing with the harddisk or any other problem???????????????
george101 is offline
Old 15-08-2007, 07:37 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Hard-disk tooooooooooo slowwwwwww
What is the System Config ??
One thing I personally noticed that When Buying new HDD, always for the 1st time do a full Format of the Drive before using, as it gives better performace, so try running a full format of the entire drive (not Quick Format) and then test with NTFS partition... also please post the details of ur full system config....
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 15-08-2007, 08:57 PM   #3 (permalink)
slugger's Avatar
have u enabled UDMA?
slugger is offline
Old 15-08-2007, 10:08 PM   #4 (permalink)
Good Boy
george101's Avatar
config:
intel core2duo e6300
intel dg965ss mobo
samsung 160gb sataII, seagate 160gb sataII, seagate 250gb sataII, samsung 80gb pata
leadtek 7300le 256mb
1gb ddrII
how to enable udma
i tried full formatting also.... no use yaar....i partitioned it as three 77gb drives.... do u think it is the problem.... plz help
Old 15-08-2007, 10:21 PM   #5 (permalink)
champ_rock
champ_rock's Avatar
not sure what is exactly UDMA.. i think u mean DMA (direct memory access)
also, i have noticd that windows 98 , ME take a lot of time as they have some different kind of file transfer engine.. use windows xp for best results
Registered Linux user number 400618
champ_rock is offline
Old 15-08-2007, 10:24 PM   #6 (permalink)
Good Boy
george101's Avatar
how to enable dma then??? i am using xp
Old 15-08-2007, 10:33 PM   #7 (permalink)
Rebooting
Go to Device Manager
Now nagivate to IDE ATA/ATAPI Controllers
un-install all entry under that, when done, restart, system will auto metically reset the UDMA
Note, In my case its Nvidia in ur case it would be Intel Controllers... and restart after u un-install all
rebooting
ChotoCheeta.com
Old 15-08-2007, 10:43 PM   #8 (permalink)
Good Boy
george101's Avatar
i tried full ormatting and also set dma.... still no use........ i dnt knw wat to do....
Old 15-08-2007, 10:47 PM   #9 (permalink)
Rebooting
Did u try what I wrote ??
rebooting
ChotoCheeta.com
Old 16-08-2007, 11:11 PM   #10 (permalink)
Originally Posted by george101
config:
intel dg965ss mobo
1gb ddrII
how to enable udma
Connect your Pata 80 gb to secondery channel dont connect anything to primary channel and try.
your smps watt????
Sawmendra is offline
Old 16-08-2007, 11:51 PM   #11 (permalink)
King of my own Castle
freshseasons's Avatar
For all that there is to know, it may just as well be a hard drive, hardware problem.
Try replacing it with another harddrive.
Given the situation, even if we consider that you do no have DMA on or did ,Quick formatting the disk, still 300mb in half an hr is slower than any old CD rom drive in PIO mode ,forget this being a harddisk.
Please have it changed and see if the same thing happens.
freshseasons is offline
another hard disk vicky_l7 Hardware Q&A 5 16-06-2007 12:56 PM
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
which hard disk to buy? tango_cash QnA (read only) 2 18-11-2006 03:57 PM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
- by kool
