Old 14-08-2007, 01:28 PM   #1 (permalink)
Web developer
narangz's Avatar
Question Query:Compaq Presario V3425AU?
Hi friends!
I want to buy a laptop in the range of Rs. 30000-38000. I have checked out Compaq Presario V3425AU It is an AMD based X2 laptop. I wanted to know whether there is any problem with AMD based laptops like heating etc. I have heard from many people that AMD based laptops have heating problems. Is it true? I have AMD X2 based desktop PC & till date never had any overheating problems but I am unsure about AMD notebooks.
Also please suggest other AMD X2 or Intel Duo based laptops in my budget.
I know I can depend upon you guys! Please help urgently. Thank you!!!
narangz is offline
Old 14-08-2007, 03:01 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
Default Re: Query:Compaq Presario V3425AU?
Ignore those who say that. You should check out the new Gemstone design based Acer Aspire 4520. It has a similar config, comes pre-installed with 1GB RAM. Price is 35k. I would say, go for the Acer if you're a sucker for white. Otherwise stick to Compaq. Both are good budget notebooks.
Sourabh is offline
Old 14-08-2007, 10:31 PM   #3 (permalink)
Web developer
narangz's Avatar
Smile Re: Query:Compaq Presario V3425AU?
Thanks Sourabh! Well I like Compaq more. If you can, please suggest other similar models. I guess the models without Windows will be cheaper. If you know any such model please let me know. Thanks you!
narangz is offline
Old 15-08-2007, 01:07 AM   #4 (permalink)
Laptoping
Sourabh's Avatar
There is nothing much to differentiate based on design and looks. V3400 and V6400 are pretty much standard. All the info and pricing for the Compaqs can be found on the HP India website. Add taxes to them and you will get the total damage. Dealers bundle free goodies like pen drives in the final price, so in the end it's just the same.
Why don't you increase your budget by another 5k and go for Dell's Inspiron 1420. It's is really worth it. You're going to stick with a notebook for a minimum of 2-years. So, investing in a better one is always a nice, will help in the long run. Your call in the end. I would say, buy a 26-27k laptop or go for the Dell.
Sourabh is offline
Old 15-08-2007, 11:26 AM   #5 (permalink)
Web developer
narangz's Avatar
Question Re: Query:Compaq Presario V3425AU?
Hi!
I also had a look at Compaq Presario V3424AU Its AMD Turion MK-38 2.20Ghz.
Now what do you recommend the V3425AU or V3424AU? I am asking this because Turions(V3424 AU) are known for better battery life & they are much cooler than Mobile Athlon(V3425 AU). What will be the performance difference? Please suggest.
narangz is offline
Old 15-08-2007, 12:49 PM   #6 (permalink)
Laptoping
Sourabh's Avatar
You're asking is single core better than dual core. Obviously that's not true. Don't go by clock speed alone. Turion X2s are better. TK-53 is a new processor which was recently introduced. It's being claimed to be based on 65nm fabrication process. So, it would be better than the MK-38 any day of the week. If you want to go with single core Turion, I would you to buy the Compaq V6404TU (Celeron M 520, 512MB RAM, GMA950) instead. HP has priced it at 27k or so.
Sourabh is offline
Old 15-08-2007, 01:47 PM   #7 (permalink)
Web developer
narangz's Avatar
No I am not asking about single core/dual core issue. I am asking whether it is better to buy turion based single core lappy as i have read that turion is much cooler & provides longer battery life. I know dual core can beat the single core any time. I am more concerned about battery longevity & a cool lappy I am sending you a link in your PM. Check it out. I was shocked after reading that particular post.
Some more info I got:
http://forums.amd.com/forum/messagev...threadid=86693
http://www.ocforums.com/showthread.php?t=515071
http://www.investorvillage.com/smbd....sg&mid=2310704
http://en.wikipedia.org/wiki/List_of...icroprocessors
narangz is offline
Old 15-08-2007, 01:58 PM   #8 (permalink)
TechFreakiez.com
Abhishek Dwivedi's Avatar
go for v3424au....i've just bought that last week....its damn cool but remember it has 128 mb graphics shared and Windows Vista Home basic which is preinstalled sucks....it only has 1 single partition of 110 gb...so it woul b better if u just ask ur engineer 2 reconfigure it and install XP insted of vista and creat more partition....best of luck...
Personal Log | Star date 05.04.2009: TDF Meet Kanpur was Awesome :D
www.TechFreakiez.com
Abhishek Dwivedi is offline
Old 15-08-2007, 02:05 PM   #9 (permalink)
Web developer
narangz's Avatar
Well I guess AMD Mobile Athlon 64 X2 TK-53 is just a Turion or similar to Turion. I wonder why they named it Mobile Athlon. Its 65nm SOI and on S1 Socket as suggested by screenshots of CPU-Z. Sourabh, your comments please.
narangz is offline
Old 15-08-2007, 03:24 PM   #10 (permalink)
Thor's Avatar
Hi, I myself bought the Preasrio V3425AU. It comes bundled with 512 MB DDR2 RAm , but I also bought an extra 512 MB DDR2 module. Now I have 1 GB DDR2. And I must say its performing just fine..
Battery life is yet to be tested by me. As I am running it on Power all the time.
But to let u know....I just disconnected the power source, lets see how long it runs. Will let u know in 4 hrs
it has got a go 6150 onboard grfx/. Which is indeed outdated , with all Go 7xxx series in the market.
I primarily got this lappy simply for high end programming ..in .net 05 / Netbeans / eclipse ...and occasional gaming.
The only thing you should keep in mind is that this model comes with preloaded vista home basic , which is a fine one, if u don't need Vista's all bells and whistles...I am doing fine with it. BUT vista being as it is, will consume 500+ MB of RAM , without any customization. So attempt to play games which are relatively new ( after 06 ) , the experience wil not be smooth. But if u can chug through net and find out which Unnecessary Vista Services to disable,and how to chow down on Vistas memorry consumption, like get it down to arnd 300 , then I deem gaming at low to med is not gonna be a too much problem. I prefer playing strategy n rpgs ..so its cool for me.
XP is not supported. Gaming wud be a breeze in this laptop had XP been supported. XP wud take hardly 150 MB of RAM.
But neither Tech Support nor HP's site , had any worthwhile drivers for this model for XP. So , I am still in the search for the drivers! ...
But as far as my requirement goes, i am doing fine with it, and its a damn sexy looking belle...
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 15-08-2007, 03:30 PM   #11 (permalink)
Web developer
narangz's Avatar
Thanks Thor! I appreciate your quick response! Also please let me know if you ever had any over-heating problems or any other problem with this machine. Also please let me know the manufacturer of RAM you purchased & how much did it cost you. Thank You!
narangz is offline
Old 15-08-2007, 03:38 PM   #12 (permalink)
Wire muncher!
infra_red_dude's Avatar
@Thor
why is xp not supported. get everest or simlar. get to know the hardware you haf, download drivers for them and install xp
infra_red_dude is offline
Old 15-08-2007, 03:41 PM   #13 (permalink)
Laptoping
Sourabh's Avatar
All the processors we're talking about here are Turions. Turions are only for laptops. Who called it Mobile Athlon? AMD have stuck witht the Turion nomenclature for some time now.
TK-53 or MK-38 both have a rated TDP of 31Watts. Both use the same Go 6150 chipset. So, there won't be any noticeable difference in battery life. Whatever you read on forums is not always correct. The battery capacity, no. of cells, load and usage all play a major part. Battery life on the budget Compaqs is strictly so-so. Expect 2.5-3 hrs max under moderate usage. Since, TK-53 is newer it will have better power saving abilities. So, going for MK-38 Turion is pointless in my opinion.
Sourabh is offline
Old 15-08-2007, 03:45 PM   #14 (permalink)
Web developer
narangz's Avatar
Hi Sourabh!
Well Compaq's site calls it Mobile Athlon. Check here
Thank you for your help!
@infra-Thanks for the suggestion man!
narangz is offline
Old 15-08-2007, 03:53 PM   #15 (permalink)
Laptoping
Sourabh's Avatar
Ok, that's very stupid of HP.
Sourabh is offline
Old 15-08-2007, 05:31 PM   #16 (permalink)
Thor's Avatar
There I am , My Laptop just shutdown , and I am back online. Last 20 min I was listening to SONGS... So i gues If I didn't I cud get still 20 - 30 min more on this time..
also I ws using chat clients (3 -> Y / G / M ) , utorrent, Norton , and one movie encoder. Hmm...gues if all u do is reading and simple writing , lap can take it more than 2.5hrs to 3 hrs.
I got a Transcend JETRAM..for 1350 + 4% tax .. 512 MB DDR2 667MHZ ..
No overheating. No Probs. I hv suggested this lappy to my other frnds too if u want a SShot of how his looks , i got tha too!
Its an awesome beauty. and comes cheap too!
@Infra , i will try that too .. though i know what hardware I have..but still I will chek if i get something diff...
Thor is offline
Old 15-08-2007, 10:33 PM   #17 (permalink)
Web developer
narangz's Avatar
Wink Re: Query:Compaq Presario V3425AU?
Thanks Thor, Sourabh, infra!!! Thanks a lot!
Btw- is rep disabled here? cant find a button to rep you guys
narangz is offline
Old 16-08-2007, 06:52 PM   #18 (permalink)
whyy dont u go for dell vostro man
hackers2005.3721 is offline
Old 17-08-2007, 08:17 AM   #19 (permalink)
Thor's Avatar
This the links for Dell Vostro.
http://www1.ap.dell.com/content/prod...sd1&l=en&s=bsd
Must say looks good..
Thor is offline
Old 18-08-2007, 03:15 PM   #20 (permalink)
Web developer
narangz's Avatar
Talking Re: Query:Compaq Presario V3425AU?
@hackers- Thanks for the suggestion buddy but I already bought the V3425AU. Thanks!
@Thor- I am going to install XP Pro SP2. Will Let you know if everything works out fine
Okay guys I have installed Windows XP Pro SP2 on my laptop. Installed all the drivers & all the devices are working fine(till now ) There is no unknown device in Device Manager.
Thor get all the official drivers you need for your V3425AU for XP from here:
Drivers
These drivers were originally for another model V3116AU. But everything works fine
You can find the newer NVIDIA Go 6150 Drivers here
Well now I plan to create a partition using Partition Magic. Didn't use fdisk cause it will delete the recovery partition too.
narangz is offline
Old 18-08-2007, 06:23 PM   #21 (permalink)
Thor's Avatar
@narangz , Buddy it seems u saved my life! I So wanted to have the Win XP Drivers for thios one.. if urs links works out.. I gonna be dancing on the stars!!!
Abt the partition thingy ,
I used Paragon partition Manager , Partition Magic is not compatible with Vista, that is atleast what the site says.
I have 60 GB for VISTA 80 GB for XP ( unfortunately yet to have a control over XP !! ), and 7 - 8 Odd GB for Recovery Partition.
Make sure to create the recovery discs right after u boot ur system for the first time ! Its of utmost importance!
Then get the Acronis True Image Home edition v10.0 installed. So right after you have all your favored appz installed and ready configured then , make the image of the partition and save it ! Will Help ya in future!
Then , remember when u install XP, the Vista from the bootrecord will be erased. to gett Back vista Boot , u wil require the Vista Boot DVD , which has Boot Repairer!
I have suffered quite a bit becoz of this hence wanted o forewarn u. if u already know...then its fine!
Thor is offline
Old 18-08-2007, 10:53 PM   #22 (permalink)
Web developer
narangz's Avatar
@Thor- Thanks for your concern bro! Well I created recovery discs before installing xp... now i am on xp with everything working fine & no unknown devices.... just download all the drivers from the HP/Compaq site(link already given) & get the newer nvidia go drivers from the other link i gave. I love XP
narangz is offline
Old 19-08-2007, 11:03 PM   #23 (permalink)
Thor's Avatar
Yahooooooo!!! thanks a load mate!
Now..in XP... I have sound drivers working, network adapter working, graphics nice and fine ...l!!! Wonderful!1!!
narangz ,,,,u a lifesaver!!.... with just over 100 MB ram consumption..I think i am all ready set to go and get them games firing full cylinders in here
Thor is offline
Old 19-08-2007, 11:19 PM   #24 (permalink)
Wire muncher!
^^^ see.. as easy as 1,2,3
Old 19-08-2007, 11:46 PM   #25 (permalink)
Web developer
narangz's Avatar
You are welcome mate, anytime!!!! Thanks for your help too I added you on yahoo too....
narangz is offline
Old 21-08-2007, 10:21 PM   #26 (permalink)
Hey here is the aks
arunks's Avatar
hey wahts the price of this laptop which thor and narang is telling...and what is its configuration
isnt this is better to purchase
HCL laptop @ Rs.34490 having
15.4" wide XGA TFT Display
Intel Dual core Processor @ 1.73GHz
512 MB ram
DVD writer drive
80GB hard disk
Carry Case Bag
Dos operating system preloaded
integrated web camera
integrated bluetooth
card reader
yours truly
arun
The aks!!
have a nice day
arunks is offline
Old 23-08-2007, 02:23 PM   #27 (permalink)
TechFreakiez.com
hey narangz...tell me how was ur XP installation....i too wana go for it....tell me plzzz how u did it...thx
well da nvidia driver is a bit heavy...can u compress using kgb and upload plzz
Last edited by Abhishek Dwivedi; 23-08-2007 at 02:23 PM. Reason: Automerged Doublepost
Old 25-08-2007, 03:47 PM   #28 (permalink)
Web developer
narangz's Avatar
nvidia drivers are already compressed mate. i installed xp from my xp sp2 cd( bootable). formatted c partition & installed xp.... then in xp used partition magic & created partitions of my c drive... recovery partition remains untouched
hey!
guys can u plz tell me how to use builtin infrared in v3425au? i cant find any irda device in device mgr... help plz
narangz is offline
Old 26-08-2007, 01:29 PM   #29 (permalink)
TechFreakiez.com
hey..i didnt knew that i have infrared....cool
Old 26-08-2007, 04:36 PM   #30 (permalink)
Wire muncher!
^^^ you haf me??!! lol..
hey buddy, never looked at device manager even once??!
Compaq presario V3000 problem Kaushal Hiwarkar Software Q&A 6 17-03-2010 11:35 AM
compaq presario driver help jithudigitised Software Q&A 4 24-04-2007 11:31 PM
Reviews of Compaq Presario V3155AU maverick123 QnA (read only) 5 27-02-2007 09:20 AM
Compaq Presario S6010IL Ablenwill QnA (read only) 4 23-10-2005 11:34 PM
- by kool
