Old 13-08-2007, 12:18 AM   #1 (permalink)
hellraiser's Avatar
Unhappy Motherboard Serial No. ????????
i got a ASUS M2n-MX motherboard. i throw away my motherboard box which have serial no printed on it.
On using EVEREST n ASUS PC Probe....i found my m/b serial no. is MB- 1234567890.
For support i want to register my m/b on vip.asus.com
But strangely site was denying the serial no. of my m/b
Q.- Is there any way to find out the serial no my m/b ????
I got to do, what i got to do...
hellraiser is offline
Old 13-08-2007, 01:27 AM   #2 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default Re: Motherboard Serial No. ????????
There must be a sticker on the mobo with the serial number, use it.
john_the_ultimate is offline
Old 13-08-2007, 09:30 AM   #3 (permalink)
Always Questioning?
emailaatif786's Avatar
Use Everest Home to find the Serial No. of your MotherBoard.
Download:
http://www.majorgeeks.com/download4181.html
:smile: Love Digit
emailaatif786 is offline
Old 13-08-2007, 11:34 AM   #4 (permalink)
No pain....No gain
Download:
He did use Everest but could not get the serial number.
Old 13-08-2007, 12:01 PM   #5 (permalink)
Always Questioning?
Angry Re: Motherboard Serial No. ????????
MB- 1234567890 ???
Totaly Incorrect!
First delete the record folder, track files, cache files and then start Everest and find the Serial.
Hey, you can also use BIOS! Just enter BIOS at startup, and there is your MB's Serial no.
:smile: Love Digit
Old 13-08-2007, 04:17 PM   #6 (permalink)
No pain....No gain
Man......... there is a sticker (with bar code) just beside your 24-pin connector, you'll find the serial number over there or just do what the above post says.
Old 13-08-2007, 04:52 PM   #7 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
else call ur hardware guy .............. u supplied u this mb ..........
... W H O T ...
ax3 is offline
Old 21-08-2007, 12:50 AM   #8 (permalink)
hellraiser's Avatar
Already mentioned i forgot to note SERIAL NO. before throwing my M/B box.
I am using Everest Ultimate Edition 4.00
Do u think ppls who sells hardware r Engineers ?????
The seller is total idiot....
Old 21-08-2007, 03:52 AM   #9 (permalink)
No pain....No gain
The sticker is on the motherboard itself, look carefully.
Old 21-08-2007, 07:12 PM   #10 (permalink)
Ankush_is_here's Avatar
Bro you can find serial no in bios by pressing del or f4 key during startup
Ankush_is_here is offline
Old 22-08-2007, 11:52 PM   #11 (permalink)
hellraiser's Avatar
Unhappy Re: Motherboard Serial No. ????????
Thats BIOS setup dear..... no help in this case....
k Bro....
I found this string on the board sticker
C68BTH7-01079-60-MIB0D0-AD1 0112
68MOACD39465
I dont which one is ma code..... if somebody has ASUS M/B........can help me to find out...
Old 23-08-2007, 06:51 PM   #12 (permalink)
Always Questioning?
For support, Just register on http://vip.asus.com and see which one is correct, by applying one by one.
:smile: Love Digit
Old 26-08-2007, 10:18 PM   #13 (permalink)
hellraiser's Avatar
Red face Re: Motherboard Serial No. ????????
Nice advice...lol
But bro will u plz help to tell that frm this string which one is ma 10 digit code ??
Old 27-08-2007, 07:30 PM   #14 (permalink)
I don't think you can get the board serial no from BIOS.
You can refer your invoice if you have it for serial no.
Generally sr. no. is mention in invoice.
Or the best option is to look on board itself.
The sticker may be anywhere on board. may be on printer port, nr. your power supply connector, on PCI slot or behind the board.
Look carefully.
kuhupihu is offline
Serial ATA DVD burner PeterShrelock007 Technology News 1 11-12-2006 07:18 AM
serial numbers of win xp sp2 pravesh_4766 Software Q&A 3 30-04-2006 08:32 PM
No serial port on A8N-VM! Lukka Hardware Q&A 3 25-02-2006 08:47 PM
Windows serial key???? Andyiz Software Q&A 7 13-02-2006 02:07 AM
USB <-> Serial cable jack// ani Peripherals 5 19-01-2006 01:05 AM
- by kool
