Old 12-08-2007, 08:11 PM   #1 (permalink)
Default intel d101 motherboard does not detect Sata hdd
I have a system with Pentium D 2.66 ghz processor, Intel D101ggc
motherboard, 512 mb DDR1 RAM, 160 GB Sata segate hdd, Asus DVD
writer, Windows xp pro sp2. My system was working fine for last 1
yr. Since last week whenever I start my system after post it is
showing the error messge "Disk failure, insert system disk and
press enter". I have changed my hdd power connecter, data
connecter, as well as smps (I m using 400 watt smps), but the bios
failed to detect sata hdd. My hdd is working fine in another
system. I have mailed to intel service centre, they advised me to
update the bios, I have updated my bios according to their
instrustion, but problem persists. Even an ide hdd is working in
my system. I have checked all the 4 sata ports. Is there any
problem in sata controller? Is there any sata to ide convertor
thus I can use my sata hdd in ide port. Pls suggest me a
solution.
Regards,
Sghosh
sghosh15 is offline
Old 12-08-2007, 08:16 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: intel d101 motherboard does not detect Sata hdd
Seems the board have some Hardware problem... Mail Intel Back bios update didnt help u cant run any SATA HDD in any of those 4 ports, where as all SATA HDDs u tested with ur boards are working fine in other D101 systems...
Intel will send Courier to pick up and send one replacement
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 13-08-2007, 02:26 AM   #3 (permalink)
solution.
Regards,
Sghosh
Its simple. Boot with your Sata HDD which shows problem "Disk failure, insert system disk and press enter", and when this msg is shown then insert the windows xp cd and press enter. It happened with me 3-4 times. And I do the same every time. Keep posting if problem persists.
abhipal is offline
Old 13-08-2007, 09:42 AM   #4 (permalink)
it may also be ur hdd failing(my guess as it happened to me ) ,.my 80GB sata hdd was working fine with my old asrock board , it had bad sectors but still it worked fine . i changed the mobo to d101 and voila , it dint detect the hdd . tried to install vista , after multiple attempts with restarting the comp and changing sata cables it detected it and i installed vista . it worked for a few hours and then it used to give way ( it wudnt redetect the hdd after comp restart ) . .got that hdd replaced and i'm running fine now. . since the ide hdd is working , check with a different sata hdd , if the same thing happens , the problem is with the sata controller , if not say byebye to ur sata hdd.
sagargv is offline
Old 13-08-2007, 09:55 AM   #5 (permalink)
You speak true my friend but the HDD does not die without any previous waring (Bad sectors) or without any problem. Sudden death of HDD can also mean that the power supply is not proper. Check for the proper earthing.
But still I think that my previous solution will work for the problem.
abhipal is offline
Old 13-08-2007, 10:31 AM   #6 (permalink)
Initially after changing cables and smps when it was not working I thought about hdd failure. And I changed a new sata hdd, but same problem persists. Infact I boot up with my win xp cd, when I press for new installation or recovery consol it was showing harddisk is not connected either it is power off or disconnected.
sghosh15 is offline
Old 13-08-2007, 05:09 PM   #7 (permalink)
Friend don't boot from the bootable cd. Start pc and when it shows error then enter the cd 1 and press enter. It will not start the installation process. It will instead start your windows.
abhipal is offline
Old 13-08-2007, 06:23 PM   #8 (permalink)
but i dont think even the BIOS is detecting his HDD...
sagargv is offline
Old 13-08-2007, 06:48 PM   #9 (permalink)
666
solomon_paulraj's Avatar
hi.. you need driver files to be created to a floppy with the help of the image file which accompanies your motherboard cd.. once you start to install windows xp through bootable cd.. press F6 to install the driver for SATA and load the drivers through the floppy.. viola its done...
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS
solomon_paulraj is offline
Old 13-08-2007, 06:55 PM   #10 (permalink)
naa , i have the same mobo and it doesnt need any extra sata drivers . i'm pretty sure his mobo aint detecting hdd and probobly needs RMA , so extra drivers wont help..
sagargv is offline
Old 14-08-2007, 02:24 AM   #11 (permalink)
"You don't think". Either you know or you don't know. There is no I think. See it and then tell.
To go to bios in d101 you need to press f2 key at the start. And there is no problem of this board with sata.
abhipal is offline
Video ram in d101 intel motherboard arunks Chit-Chat 3 14-08-2007 02:27 AM
PLz HELP! FC 6 couldn't detect sata Hdd Adhip007 Open Source 10 03-02-2007 06:50 PM
Fedora Core 3 won't detect SATA Apollo Open Source 2 30-01-2007 08:13 PM
Intel 915 OR D101??? cooldip10 CPU / Motherboards 13 22-05-2006 09:08 PM
- by kool
