Re: hard disk making snapping noises
Make sure that the data cable and power cable of the hard disk is tightly in place.
Just as intel_gigacore said, i guess bad sectors have developed on the platters of the hard disk. Try running windows checkdisk utility.
And BACKUP is the golden word, my friend. As long as the hard disk is working, Backup atleast important data.
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
