Old 11-08-2007, 09:00 PM   #1 (permalink)
bigdaddy486
Posts: n/a
Default 1394 Connection
Whenever i install windows xp, there will always be a connection installed called 1394 connection....
What is this?
Intel C2D E6300 1.86GHz
Intel DG965WH with G965 chipset
Seagate 80GB Hadrdisk
Nvidia 6200 geForce Tubro cache
a modem
hp psc 1100
Lg DVD RW 16x dvd writer
Sony Cd Rw 52x32x52x CD Writer
pctv pro 3 tv tuner
Old 11-08-2007, 09:22 PM   #2 (permalink)
King of my own Castle
freshseasons's Avatar
Default Re: 1394 Connection
1394 is the FIREWIRE port and there is nothing to be afraid about it.We can also Lan using this port.It is used to connect devices like the USB port.
Either you have a creative Audigy card which have firewire ports , or your motherboard has inbuilt firewire.
Dont worry and enjoy the speed of firewire.
Use this port when you have to transfer Videos from your Camcorder.Its also called as a DV port.
freshseasons is offline
Old 11-08-2007, 09:46 PM   #3 (permalink)
tech mighty
arun_chennai's Avatar
checkout this link "http://en.wikipedia.org/wiki/FireWire"...
arun_chennai is offline
Old 19-11-2007, 09:10 PM   #4 (permalink)
GONNA GET ALL OF YOU
JohnephSi's Avatar
How can i connect lan with dis
1394 connection. Dus it necessarydat the other computer shud also have this 1394 port.
JohnephSi is offline
Old 19-11-2007, 09:45 PM   #5 (permalink)
The High 5 Flyer
sam9s's Avatar
Yes a LAN can be built using IEEE 1394, which much better speeds (upto 400Mbps).......LAN is create like any other network.......If IEEE 1394 ports are available on both computers, connect the two computers with an IEEE 1394 cable. On each machine, Windows XP should create a new network connection and assign it an IP address. You should then be able to open a Windows Explorer window to the other computer by typing \\machine name or IP in the address bar or on run command. You'll be presented with whatever shared resources the machine makes available.(you can share a resource by right clicking on the resource, properties and sharing TAB.) At this point you can then transfer files back and forth at speeds much higher than on most other networks.
For detail tutorial I'd suggest google it.
sam9s is online now
Old 19-11-2007, 10:16 PM   #6 (permalink)
JohnephSi's Avatar
How much 1394 cable cost.
Old 19-11-2007, 10:29 PM   #7 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: 1394 Connection
Originally Posted by bigdaddy486
What is this?
Offtopic : is ur C2D 1.8GHz performance(considering only 1 proccessor) is it equivalent to Athlon64 1.8GHz(while doing testing Athlon 1.8GHz is rated as 3GHz)...
in simple i'm asking is C2D 1.8GHz(considering single proccy) == Athlon 64 1.8GHz ?
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
IEEE 1394 Which one to buy 4 SAMSUNG Handy Choto Cheeta Hardware Q&A 14 29-10-2006 09:29 PM
Front Panel USB and 1394 Connection sysfilez Hardware Q&A 18 10-08-2006 07:24 PM
what is ie 1394!!! hansraj QnA (read only) 8 30-04-2006 03:10 PM
Win XP IEEE 1394 driver problem Shikhar Software Q&A 4 13-01-2006 09:15 PM
Canon MV830i IEEE 1394 Capture Board Required. go4saket QnA (read only) 4 19-10-2005 07:52 PM
- by kool
