Old 11-08-2007, 11:29 AM   #1 (permalink)
Default Interuption while runnng CD/audio and copying files and vice versa
Hi All,
I could not understand what this problem is...
I try to copy a file from CD/DVD while my mp3 songs were played from system,there is a interruption
and the audio is disrupted.Also the mouse is jerked while moving in the screen.
The same is happening when i run cd/dvd audio from drive and do some file operation in the system.
However during this process,the system has more than 1 Gb free memory and cpu utilization is
around 50%.This is happening only when i deal with cd/dvd drives.
I have the following PC config
Intel Core 2 Duo E6700
MSI P6N SLi platinum
Win XP Pro Sp2(patch updated till jul 07)
LG DVD ROM and LG DVD writer(bought 2 yrs back)
2 GB DDR2 667MHz
80*2 GB SATA hard Drive
Avira Premium(Updated to Aug 3)
Audio Codec:realtek ALC888
GPU:NVidia xfx Geforce 8600GT 256MB
Is this problem due to audio driver or the DVD drive?Can anyone help me in solve this
issue?
Guhan
guhanath is offline
Old 11-08-2007, 05:46 PM   #2 (permalink)
Fortuna Favet Fortibus
amandeep86's Avatar
Default Re: Interuption while runnng CD/audio and copying files and vice versa
Say Goodbye to your current Optical Drive.
According to me, in a desktop, there should be atleast a secondary optical drive no matter what it does. A simple CD-Rom can be helpfull for reading CD's or DVD-Rom if you use DVDs more.
But, before buying a Optical Drive, do the following things:
1) Get your Optical Drive updated with latest firmware
If still the problem persists, then:
2) Format your PC and re-install Windows (OS)
amandeep86 is offline
Old 11-08-2007, 07:46 PM   #3 (permalink)
Hi,
I just upgraded my PC to this configuration and reinstalled OS.
I also want to add this.The sound/Audio is getting dirupt only when I run DVD in drive.The Video Cd are running fine without any disruption
Guhan
guhanath is offline
Old 11-08-2007, 08:10 PM   #4 (permalink)
amandeep86's Avatar
The Configuration of your computer you have mentioned is Very Good.
You should not be receiving such problem i guess. This problem happens only when CPU Utilisation is heavy. Well.. you should update your soundcard drivers. If still continues, uninstall new drivers & try to install a previous version of drivers.
Old 13-08-2007, 03:40 PM   #5 (permalink)
Hi,
I will let you know how it behaves after installing the new sound card drivers in 2 days
Guhan
guhanath is offline
Old 13-08-2007, 03:47 PM   #6 (permalink)
Rubik's Uncle!!
Charan's Avatar
Another thread running Interuption while runnng CD/audio and copying files and vice versa
Mods please mearge the threads
Charan is offline
Which game should be converted into a movie or vice-versa? dashingdhruv Gamerz 35 24-04-2007 11:00 PM
How to make Grub recognise Lilo or vice versa? vaithy Open Source 2 19-02-2007 07:57 AM
Convert audio to mp3 and vice versa KoRn Software Q&A 6 15-06-2005 11:30 PM
MP3 to WAV or vice versa abhinav QnA (read only) 10 12-05-2005 03:36 PM
- by kool
