Old 11-08-2007, 10:25 AM   #1 (permalink)
dr_jimit's Avatar
Exclamation RAM Questions ? etc . Pl Help ...
I've a dual boot xp Pro and vista ultimate
C2D E6230 /intel 946 gzis /1GB DDR2 667MHz/200GB SATA HDD
BIOS says single channel memmory - Are single and dual channel RAM are different? available? price ?
or they are like setting on Mobo?
I want another latest PC
What Intel Motherboard and memory will be BEST for Q6700 [or extreme editions]for 1333MHzFSB , best for 64 bit computing , dual Channel mode.
Money doesn't matter much.
Is 2GB or more size memory modules are available in mumbai, 800 MHz/more?
because only 4 GB [1GB X 4 Modules] can be added to motherboard like intel 975x
Please help, as 4 GB will be barrier for 4 CPU cores in performance in 64 bit computing.
Please answer whatever question you know, Pl before next 10 days.
Thanks in Advance,
Dr. Jimit N. Vadgama
dr_jimit is offline
Old 11-08-2007, 10:47 AM   #2 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Default Re: RAM Questions ? etc . Pl Help ...
Thanks in Advance,
Generally motherboards have two ram channels with a pair of slots in each.If u install equivalent amount of ram in each channel then u get a dual channel config.Its better than a single channel config because the theoretical data transfer rate doubles and equals the FSB speed bandwidth.For ur query regarding the pc submit in the section for BASIC GUIDE TO PURCHASE A NEW SYSTEM
Harvik780 is offline
Old 11-08-2007, 05:55 PM   #3 (permalink)
Fortuna Favet Fortibus
amandeep86's Avatar
More RAM More Speed.
Don't go for 4gb single module. Go for dual 2gb modules (Same).
Download: http://www.corsairmemory.com/_datash...6-8500C5DF.pdf
amandeep86 is offline
Old 11-08-2007, 09:56 PM   #4 (permalink)
tech mighty
arun_chennai's Avatar
get 1 more GB of same RAM & pair it up.....thats all u are in dual channel mode....(if ur MB has 4 RAM slots use both the sticks on same coloured slot)
arun_chennai is offline
Some questions executioner QnA (read only) 2 30-11-2006 10:25 PM
Questions...lots of questions... Arachnid Open Source 16 15-06-2005 12:05 PM
Three Questions shwetanshu QnA (read only) 4 09-06-2005 01:12 PM
some HDD and RAM questions..... saiko QnA (read only) 16 29-03-2005 10:50 AM
Two questions: how to? dare_dexter QnA (read only) 9 22-03-2005 10:58 AM
- by kool
