Old 11-08-2007, 10:27 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Default 390watt UPS(APC) but 620watt power supply
My brother has a 390watt UPS(APC) 650VA but a HX620W 620 watt power supply.Will it cause any problems.
Waiting for suggestions
Still waiting.I think people generally neglect such facts about mismatch of PSU wattage delivered at usage by pc and that by the UPS.
Harvik780 is offline
Old 11-08-2007, 11:53 AM   #2 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Default Re: 390watt UPS(APC) but 620watt power supply
i think this shud cause prbs in case of power failures coz a 390 watt UPS won't be able to handle the 620 watt power..
my suggestion ...get the total power supply of the PC to a socket which is connected to the invertor
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 11-08-2007, 11:55 AM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
@Harvik780
Install PowerChute software then run a Self test while system is on Load
that will give u an idea whats the actualy power requirements !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 11-08-2007, 12:07 PM   #4 (permalink)
620watts power supply doesnt mean it runs at its full power..check with the above software how much power your system uses.......if its below 500w than 650va will suffice.....but if its more than that..than upgrade your ups to 800va or 1kva
magnet is offline
Old 11-08-2007, 12:08 PM   #5 (permalink)
damn busy...
utsav's Avatar
how to know that how much power my proccy hdd and all the cabby components r using without any ups software
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 11-08-2007, 10:23 PM   #6 (permalink)
dont forget the monitor
realdan is offline
Old 12-08-2007, 09:19 AM   #7 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Smile Re: 390watt UPS(APC) but 620watt power supply
I have calculated the peak power consumption at 450 watts.So it should suffice!!
U can use PSU calculator online.
http://www.extreme.outervision.com/p...ulatorlite.jsp
Old 12-08-2007, 12:58 PM   #8 (permalink)
damn busy...
utsav's Avatar
thanx harvik
www.techjunkiez.com
utsav is offline
Old 12-08-2007, 03:38 PM   #9 (permalink)
The Devil
blackpearl's Avatar
620W SMPS does not mean that it draws 620W of power. The PC will draw only the power that it requires. 620W is the max power that the SMPS can supply, but you won't hit that mark. I can assure you that. You can easily use a 1000W SMPS with a 390W (650VA) UPS without problems.
A typical PC draws only 200-300W of power, max.
blackpearl is offline
Old 13-08-2007, 01:03 PM   #10 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
simple note - maximum of a system is equal to the lowest rated item.
Power plant (say 1000 Mega Watts) -> HT Power line (say 10 MW) -> Power transformer(say 100KVA) -> LT power line (say 100 Kva) -> power cable to home (usually 5Kva) -> power meter (usually 2kva) -> Room MCB (6amps) -> UPS (320 Watts) -> SMPS (720 Watts)
So, The maximum power transfer to the end point cannot exceed the maximum of any intermediate step.
Rollercoaster is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/65256-390watt-ups-apc-but-620watt-power-supply.html
Thread circuit diagram for APC Back-UPS Pro 500VA (BP500I) | Digit Forum | BoardReader This thread Refback 22-05-2011 06:13 PM
Power Supply gmanog Hardware Q&A 36 05-02-2007 01:19 AM
Power supply kumarn_2004 Hardware Q&A 1 24-12-2006 08:43 AM
Power Supply Problem Need Help kingshuk_sarkar Hardware Q&A 2 16-07-2006 09:03 AM
Getting the right Power Supply gxsaurav QnA (read only) 29 09-10-2005 02:18 PM
AMD 64 Power supply impetus CPU / Motherboards 4 18-01-2005 11:59 AM
- by kool
