11-08-2007, 09:27 AM
Always Questioning?
Empty DVD!
I successfully burn any DVD in my System using Nero. It also successfully runs on my system, but when I run it on any other system, it shows no files inside it, just as it is empty DVD.
What can be the problem?
My System Configuration:
Intel 865GBFHT
Intel P4 2.8HT
Dynet 1024Mb
NVidia FX5200 256Mb
Seagate PATA 80Gb
LG GSAH22N DVD-RW
Vista Premium
Nero BR 7.5
:smile: Love Digit
11-08-2007, 09:35 AM
Re: Empty DVD!
did u try running in different other systems , the problem may be with the drive of the other system . does it happen even if u write at lower speeds like 4x ?
11-08-2007, 09:41 AM
Always Questioning?
Re: Empty DVD!
1:- I gave my friend a free game burnt on that DVD at 8X SpeedBURN, but when he inserted it in his PC Drive, SETUP.exe opened automatically, but when he explored that DVD, there was nothing!
2:- I burnt a Movie at 4X SpeedBURN for my cousin, It ran successfully on his DVD PLAYER, but when he inserted it into PC Drive, it also showed no file inside it.
:smile: Love Digit
11-08-2007, 09:45 AM
Gonna make it BiG
Location: Familiar with Java... SORRY POINTER NOT ALLOWED!!!
Re: Empty DVD!
just check if its a dvd+r or not...
11-08-2007, 09:53 AM
Always Questioning?
Re: Empty DVD!
One was MoserBaer Pro DVD R and another was Amkette DVD R
:smile: Love Digit
11-08-2007, 10:04 AM
Re: Empty DVD!
well , ur fren has a virus or OS problem . there's probobly no problem with either drives although i'm uncertain as the same happened with ur cousin , r theirs old drives , can u name them ? . no hardware issue i think . the same problem was there in the computer center where i was learning C , did u try opening ur disc thru windows explorer or command prompt ( start > run > cmd ) in ur frens pc ? do a virus scan and / or do a re-install of windows . i think its best if u ask vishal gupta about this .
11-08-2007, 10:08 AM
Google Bot
Re: Empty DVD!
try opening the dvd using isobuster and check all the sessions.. Also check whether the files in it are hidden..
11-08-2007, 10:31 AM
Always Questioning?
Re: Empty DVD!
Shows only finilized 1 Session with Track in Mbs.
It happened in XP also, as well as in Vista.
Also, when I burn any DVD through my Computer, It always becomes Copyrighted, ie; It cannot copy then and shows MS-DOS Error while copying!
I made a DVD of a Flim, in my Dvive and that DVD now doe'snt Copy!
What is all that Problem?
:smile: Love Digit
Reason: Automerged Doublepost
11-08-2007, 06:02 PM
Fortuna Favet Fortibus
Re: Empty DVD!
Must be an error in Nero.
Try burning a new DVD with another software.
For Free Burning Software, Goto: www.cdburnerxp.se
11-08-2007, 06:37 PM
Re: Empty DVD!
hmm . probobly a software problem in ur pc . try re-installing nero and/or OS . does it happen when u burn the disc in vista in ur pc . further try that crappy writing CD in xp . .
12-08-2007, 06:25 PM
Always Questioning?
Re: Empty DVD!
I mentioned that it happens in Alcohol 120% and also in Nero, AND I also changed XP to Vista!
This is just 1 Problem & what about another COPYRIGHT PROBLEM?
:smile: Love Digit
12-08-2007, 06:32 PM
Re: Empty DVD!
did u format ur hdd while doing so ?
12-08-2007, 06:41 PM
Re: Empty DVD!
I read that nero version 7 has lots of bugs. The most stable version of Nero is 6.6.0.14.
12-08-2007, 06:51 PM
Google Bot
Re: Empty DVD!
^^nope... i m using nero 7.5.x.x and never had any probs wit it..
12-08-2007, 07:18 PM
Always Questioning?
Re: Empty DVD!
I can't understand your reply!
Nero 7.X is worst.
Nero Vision sometimes stops while transcoding.
Nero Showtime hangs while playing Big files.
etc etc..
_________
Now coming back to the problem,,
I successfully burn any DVD in my System using Nero. It also successfully runs on my system, but when I run it on any other system, it shows no files inside it, just as it is empty DVD. What's wrong??
Any expert here?
:smile: Love Digit
Reason: Any Expert!
12-08-2007, 07:31 PM
King of my own Castle
Re: Empty DVD!
This is definitely time to upgrade the firmware of the DVD writer
Please give us the model number and company so we can direct you to the latest firmware of the product.Or else even you can do so by googling.Just make sure its the right Firmware and from the company.
12-08-2007, 07:33 PM
Always Questioning?
Re: Empty DVD!
Intel 865GBFHT
Intel P4 2.8HT
Dynet 1024Mb
NVidia FX5200 256Mb
Seagate PATA 80Gb
LG GSAH22N DVD-RW
Vista Premium
Nero BR 7.5
:smile: Love Digit
12-08-2007, 07:35 PM
Re: Empty DVD!
do your dvd firmware upgrade.
12-08-2007, 07:39 PM
#19 (permalink)
Always Questioning?
Re: Empty DVD!
But where to get update for LG GSAH22N DVD-RW?
:smile: Love Digit
13-08-2007, 01:41 AM
#20 (permalink)
Re: Empty DVD!
Really you should have avoided LG Drives in the first place.Still...!
This model LG GSAH22N DVD-RW already has lots of problems as i can see all over the net.
I have uploaded this Firmware especially for you on rapidshare buddy.
Please download it and do the needed.Do no restart the PC until you have completly done with the updating
Download from here:
Firmware
13-08-2007, 09:28 AM
#21 (permalink)
Always Questioning?
Re: Empty DVD!
Updated the FirmWare.
Lets see the results.
"May reply the Post only after next DVD Burn!"
:smile: Love Digit
13-08-2007, 01:27 PM
#22 (permalink)
Cool as a CUCUMBAR ! ! !
Re: Empty DVD!
update firmware ....... link given above ........
install isobuster & u will find all ur sessions created on that DVD ..........
... W H O T ...
13-08-2007, 02:28 PM
#23 (permalink)
The Transcendental
Re: Empty DVD!
^ Most imp.
Did you burn the files as an ISO or a UDF?
Did you burn files or an image?
Was the disk you copied copy protected?
A screenie of the session/track using isobuster will be very helpful to sort out the problem.
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
