Old 10-08-2007, 06:35 PM   #1 (permalink)
Default Getting RAM's for by intel 845
Helo everyone,
I have a intel 845 chipset and want to upgrade my RAM. I currently have 256 mb ram. I had a decision to get 1 GB ram and was suggested to use two 512 mb ram sticks. My query is that can i use both my 256 mb and 1 GB ram sticks to work together. I was told it would lead to some problem. Since i am not sure what problem would rise, please help me regarding this. I am not a hardware geek though i would like to know how things work and what can be my solution .........
Thanks
neo235 is offline
Old 10-08-2007, 07:41 PM   #2 (permalink)
Default Re: Getting RAM's for by intel 845
It will not give you any problem if both the RAMs are of same BUS speed. If the BUS speed differs, the RAMs will not be comaptible.
ebaby is offline
Old 11-08-2007, 06:48 PM   #3 (permalink)
Fortuna Favet Fortibus
amandeep86's Avatar
Better sell that 256 mb RAM to the dealer from which you want to buy 1gb RAM. But, go for dual module kit (2 RAMS of 512 mb each).
amandeep86 is offline
Old 11-08-2007, 09:51 PM   #4 (permalink)
tech mighty
arun_chennai's Avatar
instead of spending 4k for 1gb of DDR RAM sell ur MB itself and get ASUS 945G for 2.8K and DDR2 1GB RAM for 1.7k.....(if u r in tight budget-core 2 duo 800Mhz compatible also)
arun_chennai is offline
Old 11-08-2007, 10:27 PM   #5 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Post Re: Getting RAM's for by intel 845
Does Asus 945g supports Pentium4 2.0 ghz processors??
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 11-08-2007, 10:30 PM   #6 (permalink)
Rebooting
Choto Cheeta's Avatar
@cyberboy_kerala
well its not about P4 2.0 or some thing else... its Socket which matters in this case....
Mention board I suppose was P5B-MX its one LGA 775 processor Socket one... so if that P4 is one LGA 775 then yup it will support, if its one 478 then nope it wont...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 11-08-2007, 10:34 PM   #7 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
^^ok, So is there any motherboard with DDR2 support for socket 478 Pentium 4 processors??
zyberboy is offline
Old 11-08-2007, 10:39 PM   #8 (permalink)
Rebooting
At present, no not a single one in my knowledge , infact i doubt there is none... !!!!
rebooting
ChotoCheeta.com
Old 11-08-2007, 10:48 PM   #9 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
^^I got this link now, this motherboard does have 478socket and ddr2 support isn't?? http://www.directron.com/p4m900m4.html
or is it some kind of mistake
zyberboy is offline
Old 11-08-2007, 10:54 PM   #10 (permalink)
Rebooting
ahh !!
Thanks for bringing that board to my attention... !!! OK.. it does support DDR-II but thats on VIA Chipset...
search in the market !!! may b u can find one
rebooting
ChotoCheeta.com
Old 11-08-2007, 10:55 PM   #11 (permalink)
UbuntuUser
cynosure's Avatar
If its showing then it will support.
cynosure is offline
Old 11-08-2007, 10:58 PM   #12 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
@Choto Cheeta
So my Pentium 1.7ghz processor will run on that mb with ddr2 ?
zyberboy is offline
Old 11-08-2007, 11:01 PM   #13 (permalink)
Rebooting
yup... as it writes it will !!!
http://www.biostar.com.tw/app/en-us/...t.php?S_ID=283
rebooting
ChotoCheeta.com
AMD SELLS INTEL CPUs... HAS IT COMPLETELY LOST THE WAR WITH INTEL C2D vish786 Technology News 9 09-06-2007 07:46 AM
Intel mobo for Intel Core 2 Duo E6300 !! kaps_2222 Hardware Q&A 3 21-04-2007 10:32 AM
Intel or Amd ? hellraiser CPU / Motherboards 6 28-08-2006 10:47 AM
Amd Vs Intel newbie CPU / Motherboards 1 15-08-2006 07:44 PM
Which is best.--->Intel 915P or Intel 915G vps85 CPU / Motherboards 5 20-01-2005 08:57 PM
- by kool
