Old 10-08-2007, 09:59 AM   #1 (permalink)
Default Coolermaster chasis problem
I recently purchased a cooler maser chasis. I bought a new hard disk along with it which the shop guys fixed. I bought another HDD 2 weeks later and when I tried to fit that I found that there are no drive rails and I chedked the packaging as well no extra ones either. I went and enquired they said they don't have any spare ones. My question is can i just place the hard disk in the space provided without the drive rails. Is it going to affect the HDD. I'm not that into computers bit of a noobie here. Below is the link to space (it is the 4th pic in sequence). I was talking about the one with drive rail. I have just placed the new HDD just below the one with drive rails. Any help will be really appreciated.
http://www.coolermaster.com/products...bcate=17&id=25
floyd80 is offline
Old 11-08-2007, 06:46 PM   #2 (permalink)
Fortuna Favet Fortibus
amandeep86's Avatar
Default Re: Coolermaster chasis problem
Come on dude, go and buy drive rails. They are not that expensive.
HDD without Rails will create vibration.
Not RECOMMENDED!!
amandeep86 is offline
Old 11-08-2007, 08:03 PM   #3 (permalink)
Thanks for the reply
floyd80 is offline
CoolerMaster Fan Controller goobimama Hardware Q&A 5 27-05-2007 04:13 PM
CoolerMaster Hyper48 intel Hardware Q&A 3 06-11-2005 10:36 AM
HCL infiniti pro sl 1090 Chasis intruder valtea QnA (read only) 4 29-03-2005 01:25 AM
- by kool
