Old 10-08-2007, 06:19 AM   #1 (permalink)
Vivek788's Avatar
Default IDE to SATA
Can I connect my two PATA HD to a SATA port somehow by cards etc?
Vivek788 is offline
Old 10-08-2007, 06:44 AM   #2 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Default Re: IDE to SATA
U need a pci slot ide connector card.They help u connect a pata drive when u do not have any pata ports left on mobo
Harvik780 is offline
Old 10-08-2007, 10:50 AM   #3 (permalink)
slugger's Avatar
if u run outta IDE interfaces 2 attach xtra hdd, den do wat harvik said
but if u thinkin of gettin performance boost by attachin PATA 2 SATA, den no der r no such cards 2 attach to d SATA SLOT
slugger is offline
Old 10-08-2007, 07:10 PM   #4 (permalink)
Vivek788's Avatar
its tat i am planning to take a new board with sata and new slot..but i cannot afford to purchase HDs now...so I need to connect them ....tats all..thanks both of u...
Vivek788 is offline
Old 10-08-2007, 07:34 PM   #5 (permalink)
slugger's Avatar
mobos still come with 2 IDE interfaces
so if u wan 2 continue with ur PATA HDD u can always connect dem 2 ur IDE slot and den l8r wen u buy SATA HDD transfer all d data 2 ur new HDD
slugger is offline
Old 13-08-2007, 08:42 PM   #6 (permalink)
din
Tribal Boy
din's Avatar
Small correction
IDE to SATA and SATA to IDE exist. It is like a small card + data cable for SATA + power cable for card (not for SATA device)
Cost - Rs.400
Same card work for SATA to IDE and IDE to SATA (one type at a time)
Just bought one and I will post details later. So far it is working fine - and yes I know I will not get SATA perfomance as it will go to IDE port.
din is offline
SATA ROCKS : Fujitsu intros first 2.5" 7200 rpm hard drive with SATA 2.5 interface techtronic Technology News 7 22-03-2009 11:09 PM
Sata-II hard disk working at Sata-I mode Arsenal_Gunners Hardware Q&A 27 17-03-2009 10:18 PM
Can I attach a new sata drive to my existing Seagate 80GB SATA HDD? praka123 Hardware Q&A 6 04-02-2007 06:28 PM
How to connect SATA HDD to a mobo w/o SATA port ashnik Hardware Q&A 7 31-03-2006 08:52 PM
wats better Hitachi(SATA) 80gb or Samsung(Sata)80gb ??? King_Niral QnA (read only) 12 14-08-2005 05:11 PM
- by kool
