Old 08-08-2007, 02:51 PM   #1 (permalink)
Default intel DG 33 FBC or ASUS P5K-VM
which mobo to go for intel DG 33 FBc is 5800 where as asus P5K-VM is above 7000. The specifications seems to be similar. My proc will be C2D 6550 with 1333 MHz FSB.
gksunil is offline
Old 08-08-2007, 07:07 PM   #2 (permalink)
Default Re: intel DG 33 FBC or ASUS P5K-VM
asus p5k-vm all the way . intel board doesnt allow OC and is a waste on C2D .i dont think the asus board has integrated gfx i think , not sure .. but neway dont buy intel mobo .
sagargv is offline
Old 08-08-2007, 09:37 PM   #3 (permalink)
deathvirus_me's Avatar
Anything besides Intel boards ..
deathvirus_me is offline
Old 08-08-2007, 11:14 PM   #4 (permalink)
Google Bot
Pathik's Avatar
get the asus p5k vm.. It also has the x3100 onboard gfx.. Btw if i were u i wd get a xfx 650i ultra with a temporary 2k 2nd hand gfx card like the 7300gt
Pathik is offline
Old 09-08-2007, 12:06 AM   #5 (permalink)
The Transcendental
^Asus P5K-VM should you want more juice.
Check out other Asus models as well, preferably without onboard graphics and with as many supported PCI express/PCI bus you can find. Get yourself a good graphic card 7300/7600gt along and you have a decent rig.
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 09-08-2007, 09:57 AM   #6 (permalink)
Pain is Forever
rohan4pal's Avatar
yaa go for 7600GT if u r not low on budget
If it's true that we are here to help others,
Then what exactly are the others here for?
rohan4pal is offline
Old 09-08-2007, 10:31 AM   #7 (permalink)
tech mighty
arun_chennai's Avatar
is ASUS P5K-VM available for 7k???...if yes means get it.....heard that board overclocks well unlike the P5B-VM....better than XFX650i....
arun_chennai is offline
Old 09-08-2007, 10:44 AM   #8 (permalink)
The Transcendental
^I can verify that Asus p5kvm is available for 7k
Old 09-08-2007, 05:47 PM   #9 (permalink)
tech mighty
if it is true then we have a new budget overclocker....(6750+p5k-vm==15k and it can reach 400FSB easily--3.2Ghz)...3.2Ghz from uATX is very good....
Old 11-08-2007, 06:50 PM   #10 (permalink)
I baught ASUS P5K-VM for 8.5K today in Mumbai. Where do you get it for 7K.
kranti is offline
Old 11-08-2007, 11:36 PM   #11 (permalink)
moshel's Avatar
P5K-VM has onboard graphics, not too great but it does support pixel shader 2.
but i suggest u go for this only...dont go for intel.
moshel is offline
ASUS P5GL-MX Vs INTEL ORIGINAL 915 GAVL vasulic Reviews 14 19-10-2009 12:56 AM
ASUS P5N-E SLI or INTEL DG965WH? xsreality Hardware Q&A 13 07-06-2007 01:59 AM
WHich MotherBoard is best...AsUS or InTel thinkdigitreader Hardware Q&A 28 13-02-2007 10:03 AM
Intel D865GBFL vs. Asus P4P800-VM shyamthakkar CPU / Motherboards 15 28-10-2004 08:00 PM
- by kool
