Hi all,
I have been facing this problem with my (IDE)HDDs.
I have two 40GB Samsung and one recently purchased 160GB Seagate harddisks.
I connected 160GB hdd as Primary Master, 40GB hdd as Primary Slave and a DVD drive as a Secondary Master. I have successfully installed XPPro OS on the Seagate 160GB drive.
But when I again started the PC 2/3rd time, the boot gave me warning that S.M.A.R.T has detected a failure in your Samsung 40GB disk. Please immediately backup the data. I pressed F1 to continue and it started scanning for errors on the disk. It gave error something like 'Error reading part of sector 4509...'. I restarted then..but again it gives this error plus my 160 GB hdd was now undetected in BIOS. Please help. I need to get that hdd working. Whats the possibility to recover my data after suppose the bad sectors are present on HDD?
So finally I unplugged the Samsung 40GB disk and now it booted w/o problems. But I hear some noise in the Seagate hdd while running though I don't see any performance effect due to it. Is it normal?
Is the connecting cable at fault or my SMPS rating is low? or it is a problem with the HDD itself?
Configuration: Athlon XP 2400+, A7N-266VM mobo,
230V SMPS
