Old 07-08-2007, 09:30 PM   #1 (permalink)
Resident Fanatic
Manshahia's Avatar
Question pendrive converted into 3.23 Gb from 1 Gb??
i m having a 1 Gb transcend pen drive....
Today when i inserted it it showed its capacity as 3.23 GB ..
wat happened to it??
Manshahia is offline
Old 07-08-2007, 09:52 PM   #2 (permalink)
NP : Crysis
xbonez's Avatar
Default Re: pendrive converted into 3.23 Gb from 1 Gb??
how much data does it take?? i 1gb, then don't bother, if 3.23 GB, then jump with joy
xbonez is offline
Old 07-08-2007, 10:25 PM   #3 (permalink)
try formatting it again . or was it just a glitch ? i.e.. did it show as 1gb when u re-inserted it ?
sagargv is offline
Old 08-08-2007, 12:27 AM   #4 (permalink)
Turn The Page
pannaguma's Avatar
Location: The name of the place where I live is too big to fit in this place, so I am not mentioning it !!!
sell it on ebay for $10000
This Space Has Been "RESERVED" !!!
pannaguma is offline
Old 08-08-2007, 02:09 PM   #5 (permalink)
Fortuna Favet Fortibus
amandeep86's Avatar
Talking Re: pendrive converted into 3.23 Gb from 1 Gb??
Tell us the procedure so that we can make our 2gb pen drive into 4.7 gb.
LOL.
amandeep86 is offline
Old 09-08-2007, 09:44 AM   #6 (permalink)
The Transcendental
Did you format it with NTFS with compression and add data to it?
If not, the drive needs to be reformatted as this happens only when data gets corrupted. I have had such problems with faulty flash memory cards
(once a 256 mb card was showing 1gig. It died soon after. RIP :'((
:sniff: It cost me 2k back then)
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 09-08-2007, 05:05 PM   #7 (permalink)
format in ntfs partition and i have one problem like this what is this means when i insert my pen drive into the rig then it will show that the pen drive is connected.but when i try to open it please insert your disk drive.
thecreativeboy is offline
Old 13-08-2007, 03:24 PM   #8 (permalink)
Resident Fanatic
Manshahia's Avatar
nope.. i cant add more than 800 MB data into it.. after that it gives an error..
its in warranty... and i think they will replace it..
which is the best pendrive? max_demon Hardware Q&A 44 06-12-2009 07:30 PM
autorun from usb pendrive rajdeepsingh86 Peripherals 1 08-11-2006 10:37 PM
Pendrive Needed aditya.shevade QnA (read only) 14 17-07-2006 10:15 PM
using a pendrive on win98 mvishnu Software Q&A 2 15-03-2006 08:53 PM
- by kool
