Old 07-08-2007, 08:14 PM   #1 (permalink)
4Ghz Here I come !
Demonkiller's Avatar
Default Computer Wont Boot Up
Well I didnt use my comp for 2 weeks and now when I try to turn it on it beeps 3 times and nothing happens. I tried removing and inserting the memory and bios battery. No give. Any help?
Demonkiller is offline
Old 07-08-2007, 08:21 PM   #2 (permalink)
Fortuna Favet Fortibus
amandeep86's Avatar
Default Re: Computer Wont Boot Up
I think this is a RAM Problem
amandeep86 is offline
Old 07-08-2007, 08:30 PM   #3 (permalink)
Back to School Mr. Bean !
mod-the-pc's Avatar
RAM faults give a single long beep. The 3 beeps sounds like a display problem. Try removing your AGP/VGA card and re-inserting it.
Desktop: P4 2.8E, Intel 865GBF, 512MB Hynix PC3200, Samsung SV1204H 120GB, Samsung SW-248F, Creative Inspire 4400, Samsung 793MB, Compro PVR/FM, WinLIRC
Laptop: HP Pavilion dv8210us
mod-the-pc is offline
Old 07-08-2007, 08:33 PM   #4 (permalink)
4Ghz Here I come !
Well in the motherboard instruction booklet it says that 3 beeps is a no memory error.
Old 07-08-2007, 10:54 PM   #5 (permalink)
EXPLORING!!!!!
sid_sh85's Avatar
thts a perfect symptom of faulty ram wich happens commonly these days due to moisture as a reult of monsoon.....try cleaning the ram modules...also, if u hav 2, it s quite possible dat 1 of them must have bcum dead...so remove 1 at a time and test...all d best
_____________________________________________
AMD Phenom II 920__GIGABYTE GA-MA78GM__1.75TB HDDs__6GB DDR2__CORSAIR VX550___ZOTAC GTS 450 Amp Ed!!___Samsung Syncmaster B2230__DELL INSP 15
sid_sh85 is offline
Old 08-08-2007, 05:17 PM   #6 (permalink)
4Ghz Here I come !
I removed my 7300gs and a 1gb module and it booted up fine. Tried using the faulty ram on single channel and same error. Even graphics card. I guess both have gone kaput.
Old 08-08-2007, 06:28 PM   #7 (permalink)
Distinguished Member
anandk's Avatar
No of Beeps- Description of Problem:
No Beeps- Short, No power, Bad CPU/MB, Loose Peripherals
One Beep- Everything is normal and Computer POSTed fine
Two Beeps- POST/CMOS Error
One Long Beep, One Short Beep- Motherboard Problem
One Long Beep, Two Short Beeps- Video Problem
One Long Beep, Three Short Beeps- Video Problem
Three Long Beeps- Keyboard Error
Repeated Long Beeps- Memory Error
Continuous Hi-Lo Beeps- CPU Overheating
now thats a lot of beeps, eh !?
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 08-08-2007, 07:08 PM   #8 (permalink)
4Ghz Here I come !
Turns out my ram is at fault. Graphic card works fine. Rushes off to change the memory.
e6750 Lapped(3.2Ghz Constant),AC7,P5N-e SLI,XMS2 1066 2x1+G.Skill PK's 2x1Gb,Ultra X2 750W,EVGA 8800GT SC+Galaxy 8800GT SLI
e4300@3.5 http://valid.x86-secret.com/show_oc.php?id=310431
machine wont boot! jambay19 Hardware Q&A 1 28-07-2007 07:42 PM
help: PC wont boot :(( Jags Software Q&A 3 29-04-2007 11:12 PM
System wont boot.......fdisk wont work.......xp wont install irradiated_chicken Software Q&A 10 10-06-2005 10:50 AM
Computer Wont startup!!!! rachitar QnA (read only) 17 09-03-2005 01:30 AM
- by kool
