My Frined has 4 Office in 1 Bldg, so he has attached 8Cameras on his all the office
Now where is his cabin he need to view all the cameras
All the Setting has been done
all the 8diff wires of all the cam comes to 1 big-box & frm their 1 Single wire come out, It is like a Cable Wire Pin (they call it RC pin)
So he bought 1 GADMEI Combo TV Box - "CTB"
He attached that single RC Pin (coming from big-box) to the 'Cable In' port of "CTB" but it was not working
Monitor was not displaying cameras
He can view the blue screen,channel no on the monitor & can change the Channel with Remote
but cam was not displaying
So the thing is CTB was working only cam was not connected
now he attached that RC Pin on TV & it was working fine
Now i brought that to my home &
I attached cable wire, power adapter & my 17" Flat Monitor on it & it was running perfectly
But when he attach on his cam
nothing work
The Only Difference in my Home & His office is Type of Cable Pin & Monitor
I am attaching diagram for you
The Difference in Pin
Pls help me if you can understand this........?
