Old 06-08-2007, 10:54 AM   #1 (permalink)
a_tif's Avatar
Unhappy DVD writer wont read cd's
all of a sudden today i found that i m unable to read cd's in my dvd writer
it is a SONY DVD RW DRU-820A
it is reading all dvd's but not cd's
it is only reading countable cd's
rest of the cd's are read as black or r not detected at all
pls help me out.
a_tif is offline
Old 06-08-2007, 10:56 AM   #2 (permalink)
Pain is Forever
rohan4pal's Avatar
Default Re: DVD writer wont read cd's
pls help me out.
can u tell us wht types of CDs r tht...
If it's true that we are here to help others,
Then what exactly are the others here for?
rohan4pal is offline
Old 06-08-2007, 10:59 AM   #3 (permalink)
Cool G5's Avatar
Post Re: DVD writer wont read cd's
Try firmware upgrade.
Cool G5 is offline
Old 06-08-2007, 11:01 AM   #4 (permalink)
a_tif's Avatar
all cd's
movies
pictures
games
apps
even digit n chip cd's
a_tif is offline
Old 06-08-2007, 12:21 PM   #5 (permalink)
=CrAzYG33K='s Avatar
I'm not sure ..
but could it be a Booktype setting problem?
You can get more info/support at ClubCDfreaks...
\\~o~// SpId3Y FaN \\~o~//
=CrAzYG33K= is offline
Old 06-08-2007, 01:14 PM   #6 (permalink)
a_tif's Avatar
i updated firmware
it now reads some cd's but not all
n it is taking long time to read a cd
on the other hand dvd is read a lot faster campared to cd
a_tif is offline
Old 06-08-2007, 02:55 PM   #7 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Talking Re: DVD writer wont read cd's
dude try crossflashing it to a nec drive and then try....but be sure to also download the lates firmware for the 820a...u find all info regarding this at liggys firmware page or clubcdfreaks..
Wadadadada!! ??
Ambar is offline
Old 07-08-2007, 04:33 PM   #8 (permalink)
a_tif's Avatar
Angry Re: DVD writer wont read cd's
well isaw one of the similar posts in the forum n found that a worm called brontok affects the cd and dvd drives
i scanned my system and to my bad luck i found it
how do i remove it
a_tif is offline
Old 07-08-2007, 06:02 PM   #9 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Smile Re: DVD writer wont read cd's
udi baba....never heard of a worm giving crc errors (lolz).........neways....type the exact name in google like....W32.brblahblahblah....and ull get the removal tool frm symatec website......
Wadadadada!! ??
Ambar is offline
Old 07-08-2007, 07:58 PM   #10 (permalink)
a_tif's Avatar
i removed that worm
forums said it affects optical drives
but my problem is still not solved
dvd's still run
but when u put a cd in it makes weird noises
it is not reading any cd's
i upgraded the firmware already
it made dvd's autoplay faster but cd's still not working
is this an os issue
a_tif is offline
Old 08-08-2007, 10:34 AM   #11 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Wink Re: DVD writer wont read cd's
no if the drive is making some noises then no firmware can help...take to the service senter (rashi peripherals for the sony)....
Wadadadada!! ??
Ambar is offline
Old 13-08-2007, 06:56 AM   #12 (permalink)
a_tif's Avatar
the funny thing is that it makes no noise n reads dvd's smoothly
but as soon as u insert a cd it starts makes noise n stops spinning
i uninstalled the driver
n then scanned for devices to reinstall it
i get a msg that the driver is not digitally signed
ya it even burns dvd's
i dont get it whr the problem lies
a_tif is offline
Old 13-08-2007, 09:19 AM   #13 (permalink)
try a format and re-install windows
sagargv is offline
Old 13-08-2007, 10:47 AM   #14 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
boss why dodnt u take it to the service center....if its making noises then most probably the head alignment has gone wrong....most probably ull get a new drive..
Wadadadada!! ??
Ambar is offline
Old 13-08-2007, 01:10 PM   #15 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
can someone tell me what a 'countable CD' is?
Rollercoaster is offline
Old 13-08-2007, 04:44 PM   #16 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
try attaching & reading those cds @ ur frds place ............
if same problem then move 2 service center ............
... W H O T ...
ax3 is offline
Old 13-08-2007, 08:05 PM   #17 (permalink)
a_tif's Avatar
well i have a old cd-rw drive too
all cd's work in it
the problem is with dvd rw drive
i will have to take it for servicing
a_tif is offline
Old 13-08-2007, 08:21 PM   #18 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
ummm...boss wht urpose is this gonna solve??
Wadadadada!! ??
Ambar is offline
Old 13-08-2007, 08:52 PM   #19 (permalink)
that'll eliminate the possibility of any worm .
sagargv is offline
Old 13-08-2007, 10:48 PM   #20 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
as far as i noe...there is no worm which falters the working of a optical drive...if u guys noe of one...plzz do tell.
Wadadadada!! ??
Ambar is offline
Old 14-08-2007, 08:17 PM   #21 (permalink)
your dvd writr is defected. I have also faced this problem in past but i have replaced my dvd writer under warranty
abhijangda is offline
DVD writer doesn't read CDs well adithyagenius Hardware Q&A 7 08-06-2007 06:39 PM
CD DRIVE UNABLE TO READ CD'S rahulshankar Software Q&A 5 17-04-2006 01:39 PM
System wont boot.......fdisk wont work.......xp wont install irradiated_chicken Software Q&A 10 10-06-2005 10:50 AM
not able to read Digit Cd's --URGENT online_marketeer QnA (read only) 8 20-03-2005 04:32 PM
- by kool
