Old 06-08-2007, 10:26 AM   #1 (permalink)
darklord's Avatar
Smile XFX 650i Ultra : Another look ! + Testing with Q6600
A friend of mine wanted to upgrade his PC and so i got a call from him, asking me what he should do,what he should get and so on.
After a lot of discussion, we decided to get the following for his upgrade -
1] XFX 650i Ultra Motherboard
2] Intel Core2 Quad Q6600 [B3 ]
3] Corsair Value select 1GB x 2 DDR2 667Mhz Memory kit
4] Seventeam 500-BKP PSU
Yesterday was a sunday and i had nothing better to do, so i thought,why not check out the board closely and see what the 'B3' is capable of and why people curse it so much
So here we go,
The Box,Package...
The Board -
Continued..
darklord is offline
Old 06-08-2007, 10:27 AM   #2 (permalink)
darklord's Avatar
Default Re: XFX 650i Ultra : Another look !
Continued..
BIOS Shots - [Note: Bios P03 which released recently was flashed]
Continued...
darklord is offline
Old 06-08-2007, 10:29 AM   #3 (permalink)
darklord's Avatar
Continued...
Some Observations -
Pros -
1] The board layout is simple and almost perfect
2] From the looks, the quality of components used, especially in the CPU socket area seems very high.
3] No Heatpipe jungle
4] Not much headaches, works flawlessly, out of the box.
Cons -
1] Even though the heatsink is chunky on the NB, trust me, it gets mighty hot.
2] Bundle that came along with the board, was nothing exciting, god knows why XFX made the Box so Huge !
3] The BIOS is seriously lacking in the Overclocking department.Needs better options on the voltage front.
I will be testing this board with a Q6600 CPU, i have already played with it with a Core2 Duo but am eager to see what it can do with a Quad.
Stay Tuned !
Edit : Testing added -
Stock Air Cooling -
I started off with a pretty clean setup as you can see. Then i remembered reading somewhere, about the 650i heat issues, immediately i tried touching the big,chunky heatsink and man, was it steaming hot !
I just don't like chipsets getting too hot, i installed a simple 80mm DC Fan over it to cool it down.
As i wasn't going to do any extreme clocking since i don't have a good PSU, i didn't bother much but i am dead sure, this chipset will need some better cooling for extreme benching.
Results with Stock Air Cooling -
Temps don't look good on stock cooling under load
Watercooling for CPU -
Once i realized, stock cooling isn't that great, i wanted to see what water could do
Results with Watercooling -
Let me tell you that, i was using Swiftech Apogee which is NOT designed for Quad Core CPUs. Still i feel, it did a pretty decent job of cooling,at least at stock,
Nothing great but still, much better that stock cooling
With temperatures within safe limits, i wanted to 'play' with the chip
I set 1333 FSB in BIOS and tried booting, no boot into windows, upped the voltage to 1.4V [Real : 1.36V]
Booted into Windows, as soon as i started Orthos, everything shutdown. No crash, no BSOD nothing, simple as power outage. I guessed that the PSU wasn't handling it [Read: Powersafe 400W being torchered ]
I tried 2.8GHz, same thing. Then i tried 2.6GHz but then no point in testing at 2.6GHz so i called it a day.
I will be receiving my Seventeam 600W today hopefully, once its here, i will resume the REAL testing.
Till then, Stay Tuned !
Amey,
Team THL
darklord is offline
Old 06-08-2007, 11:17 AM   #4 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default Re: XFX 650i Ultra : Another look ! + Testing with Q6600
Now that's an excellent review......waiting for the results with the new PSU. Anyway, could you please check if the pc works fine with all the memory slots occupied.
Or just check the memory slots indivisually. Mine and few of my friends mobo had to be replaced since some had one or even two faulty memory slots.
john_the_ultimate is offline
Old 06-08-2007, 12:12 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
thats an excellant review!!!
one thing i liked abt the board: placement of the battery!
one thing i think can do better: placement of the ide connector.
one thing that surely needs to be improved: overclocking options.
infra_red_dude is offline
Old 06-08-2007, 01:16 PM   #6 (permalink)
darklord's Avatar
Recd. my Seventeam, will be testing this evening. Will try out whatever you want and post back here.
darklord is offline
Old 06-08-2007, 01:35 PM   #7 (permalink)
Google Bot
Pathik's Avatar
darky u rock.. I was waiting for this.. But y didnt u get the g0 stepping q6600..
Pathik is offline
Old 06-08-2007, 02:44 PM   #8 (permalink)
darklord's Avatar
Its not my chip, a friend bought it
darklord is offline
Old 06-08-2007, 02:53 PM   #9 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Talking Re: XFX 650i Ultra : Another look ! + Testing with Q6600
dood gr8 analysis.....btw do u know how to make a water block...or frm whree to get one??
Wadadadada!! ??
Ambar is offline
Old 06-08-2007, 03:37 PM   #10 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Can u tell me where u got that seventeam psu from.Abroad??
Harvik780 is offline
Old 06-08-2007, 03:39 PM   #11 (permalink)
Hells_Fury's Avatar
Hmmm...temps dont look too good at all...
Q6600 G0 (TR Ultra-120), ASUS P5N32-E SLI, eVGA 8800GTX Superclocked (TR HR-03 Plus), Samsung 940BW, Corsair Dominator PC2-8500, CM Stacker 830, 700GB Storage, Corsair HX620W, APC Smart 750VA
Hells_Fury is offline
Old 06-08-2007, 03:50 PM   #12 (permalink)
tech mighty
arun_chennai's Avatar
wow wow wow....exciting yar....eagerly waiting for ur continuation....
arun_chennai is offline
Old 06-08-2007, 07:44 PM   #13 (permalink)
Treatment in progress...
mukherjee's Avatar
Originally Posted by darklord
Continued...
Stock Air Cooling -
Could you please guide me as to how to place the 80mm fan on top of the north bridge?
also recommend a fan/heatsink/fan+heatsink solution for the southbridge.
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
Photography: Nikon D5100||Nikon 55-300 VRII
Canon Powershot SX220HS||Tamrac Velocity 9x
Audio Gear: Brainwavz M4||Meelec A151|| EP630
PX100 II||Fiio E5||AudioTechnica ATH-T500
mukherjee is offline
Old 06-08-2007, 08:15 PM   #14 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Asus Commando based on the 965 chipset would have given better performance as i have seen that the mobos based on intel chipset perform better than the ones from nvidia and via in cpu scores.I don't know about its overclocking capabilities but i guess it should be a good overclocker as its from asus also its got the logo of "Republic of gamers".And please answer my query about the seventeam psu.
Old 06-08-2007, 10:41 PM   #15 (permalink)
darklord's Avatar
Making a waterblock is not that easy. You can purchase it from abroad. They are available with Sidewinders, they ship to India.
I got it locally. Got it couriered from Mumbai
ST-500BKP = ~ 3800/-
ST-600EAD = ~ 7900/-
Welcome to the world of Quad Cores !
Please note, Swiftech Apogee is not a block designed for Quad Cores. Guess i will have to stop being lazy and mount that Dtek Fuzion i have
For benching, i have kept the 80mm on the heatsink, since its not a High CFM fan, it doesnt move around
Cooler for SB = Coolermaster BlueIce, perfect one.Its the same one i used in Singapore on the Asus P5K3 Deluxe when i ripped the Heatpipes apart
You think i am not aware of 965 performance capabilities ? Commando is an excellent mobo, great overclocker. Please note, this setup is for a friend.He didnt want a uber expensive mobo.Also Commando is ridiculously priced at 14k+ and now that P35 is out,it doesnt make sense to get 965
darklord is offline
Old 06-08-2007, 10:47 PM   #16 (permalink)
mukherjee's Avatar
Where to get the coolermaster from? and the price?
Any permanent fan solutions for the northbridge at an affordable rate?
Old 06-08-2007, 10:50 PM   #17 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
dood collermaster is available from SMC international.....ya a permanent fan solution for northbridge is a small fan paste it on the north bride...all done
Wadadadada!! ??
Ambar is offline
Old 06-08-2007, 10:51 PM   #18 (permalink)
darklord's Avatar
You can try Thermalright HR-05 which is available with Prime ABGB, Mumbai.
As for coolermaster, its for 400-500 i guess, try contacting Coolermaster dealer or so.
darklord is offline
Old 06-08-2007, 10:54 PM   #19 (permalink)
mukherjee's Avatar
well,any links for the contacts or something?
price for the thermalright?
Old 06-08-2007, 10:56 PM   #20 (permalink)
darklord's Avatar
No idea , sorry
darklord is offline
Old 06-08-2007, 10:57 PM   #21 (permalink)
Rebooting
Choto Cheeta's Avatar
Coooool.... Review.... !!!
@darklord
That power outage happend with me too, dont know why but when i increased that vcore up to 1.5v in my case of E6600 i was able to archive one stable system !!!
u are with water cooling so, 1.5v.. would it be a problem ...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 06-08-2007, 11:00 PM   #22 (permalink)
darklord's Avatar
@darklord
The power outage was caused because Quads literally gulp power off the PSU.Powersafe 400W was never going to cut it but then i couldnt wait
Now that my Seventeam is here, i am gonna start playing again
I have pushed 1.725V through my E6600 when i did 4GHz under water on my P5N32-E SLI so 1.5 is no big deal
darklord is offline
Old 07-08-2007, 03:07 AM   #23 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
I guess ur right.
Old 07-08-2007, 08:47 AM   #24 (permalink)
UbuntuUser
cynosure's Avatar
When is the other part of the review coming up?
cynosure is offline
Old 07-08-2007, 09:40 AM   #25 (permalink)
darklord's Avatar
I received my Seventeam PSU yesterday so did some more testing with the PSU.
Seventeam ST-500BKP
Following are the results,
3.2 GHz to begin with, Dual Orthos run at Priority 8,
3.4GHz ,
Beyond this i couldnt push, maybe chipset voltage was falling short or the board had reached its limits or chip reached its limit, i dont know. I am guessing its the chip because, dropping the multiplier, i could easily bench at 400FSB. One more thing i liked about this board is even though it is a Value board, it could manage 400 FSB on Quad Core which i feel is awesome.
Some 3DMark 2006 run to test stability ?
Amey
darklord is offline
Old 07-08-2007, 09:45 AM   #26 (permalink)
Rebooting
Dont u feel 67C temp is on a little Higher side
I thought we are not suppose to cross that 60c mark !!!
whats the vcore on 3.4 GHz ??
rebooting
ChotoCheeta.com
Old 07-08-2007, 09:50 AM   #27 (permalink)
darklord's Avatar
Its fine for Quads Vcore = 1.39V
You seriously dont know how these Quads spit out Heat. They are fire monsters or something.
Also how many times do i tell you guys, Swiftech Apogee is NOT a Quad Core friendly Waterblock
But considering that with stock cooler, at stock speeds, the temps were hitting, 78-79c at load, i am not complaining if it remains in 67c range at 1 GHz more speed. Mind you , its 4 friggin cores !
Amey
darklord is offline
Old 07-08-2007, 09:56 AM   #28 (permalink)
hey pals.....
wherer can i get Akasa AK-210 Chipset Cooler for my nb...
as its nit much costlier and has a heatsink + fan desigh,,,,,
thanx...
angel
The Day Walker! is offline
Old 07-08-2007, 12:30 PM   #29 (permalink)
No pain....No gain
Akasa-210 http://www.sidewindercomputers.com/akakchco.html
Old 07-08-2007, 06:31 PM   #30 (permalink)
Fast 'N' Furious
topgear's Avatar
Thank U very much darklord for your great DIY & bts (blood, tears & sweat - just kidding) effort. This will come very handy for any 650 ultra mobo user like me.
Also don't forget to post your benchmarks result here:
Post Your Benchmark Results Here
Also Follow this Guide. This will help U very much:
http://www.nvidia.com/docs/CP/45121/...erclocking.pdf
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Which Nvidia Ultra 4 Mobo ? ? ? tiblu Graphic cards 1 27-04-2006 11:37 AM
Premium vs. Ultra g_goyal2000 QnA (read only) 6 11-12-2005 07:44 AM
What is the difference between LE,GT,XT,Ultra dcp15121980 QnA (read only) 4 16-11-2004 11:34 AM
- by kool
