Old 05-08-2007, 05:55 PM   #1 (permalink)
Lightbulb Help needed for micro SD card
i have a 1Gb Micro SD card which is password protected. Now, i am not able to access it because i dont remember the password.
even to format it password is required. and windows is detecting the removable drive but not able to access or format it too.
is there any application to format it???
Please help.....
Thanks
mahip7 is offline
Old 05-08-2007, 07:12 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Help needed for micro SD card
google for "MMCMEDIC"
Pathik is offline
Old 05-08-2007, 07:24 PM   #3 (permalink)
Fortuna Favet Fortibus
amandeep86's Avatar
You can try formatting it in a cell phone.
amandeep86 is offline
Old 05-08-2007, 09:22 PM   #4 (permalink)
Please help.....
Thanks
Did you lock it with any external application or through the option that is provided in the phone. If the case is latter you should insert the card in the phone through which you locked it and you would be able to access the files on it. To format it you can find tools by searching on google.
ThinkFree is offline
Old 07-08-2007, 04:39 PM   #5 (permalink)
thanks but MMCMEDIC isnt working for my mmc
i had locked through option provided in the mobile
mahip7 is offline
Old 07-08-2007, 06:01 PM   #6 (permalink)
In the first post the issue is about an SD card and now it has become mmc.
V.Prem Kumar
janitha is offline
Micro SD memory card JohnephSi Mobiles and Tablets 5 26-06-2007 02:30 PM
Help needed to Buy New Graphics Card josenoel Graphic cards 4 03-01-2006 07:25 PM
Help needed again for a graphics card techno tublai Graphic cards 8 23-05-2005 08:18 AM
- by kool
