Old 04-08-2007, 05:54 PM   #1 (permalink)
bigdaddy486
Posts: n/a
Unhappy Help..........
I had buyed a billiontonbluetooth adapter class 1 100 mts and installed bluesoleil which is bundeled with it. I have uninstalled it because it cannot send files to my mobile-motorola a1200..............
And then i installed widcom bluetooth software which is bundled with motorola phone tools and it says it can't find bluetooth adapter...........
What should i do?
Old 04-08-2007, 06:00 PM   #2 (permalink)
sam_1710's Avatar
Default Re: Help..........
Which os are you using ?? .. VISTA??
C2D E8400, MSI P45 Neo-F, Sapphire HD4850, Dell 2409W, OCZ 2*1GB RAM + 1*2GB Transcend + 1*1GB Transcend , Seagate 1TB + 2*Seagate 80GB, 600W SMPS, APC 600VA, Creative EP630, Sennheiser HD202 :)
sam_1710 is offline
Old 04-08-2007, 06:17 PM   #3 (permalink)
bigdaddy486
Posts: n/a
nop..........
Windows XP Media Centre Edition 2005 Service Pack 2
Old 04-08-2007, 06:22 PM   #4 (permalink)
sam_1710's Avatar
hmmm... then can u be more specific about the problem?? like.. wat error message is being displayed??
sam_1710 is offline
Old 04-08-2007, 06:55 PM   #5 (permalink)
bigdaddy486
Posts: n/a
When i a double clicking My bluetooth places, Nothing happens and when i double click on bluetooth icon on system tray,The error message is
"Bluetooth device not found.
Please veify that Your Bluetooth device is properly connected and turned on."
I have connected the bluetooth adapter and a light is appearing on it when ever i turn on the pc as since i have pluged it on my computer for first time......
Old 04-08-2007, 06:57 PM   #6 (permalink)
sam_1710's Avatar
Is this error message displayed with Bluesoleil drivers or with the Widcomm drivers??
sam_1710 is offline
Old 04-08-2007, 07:43 PM   #7 (permalink)
bigdaddy486
Posts: n/a
I think with widcomm................
and now i installed bluesoleil tooooo and it worked but widcomm with the same error message.............
Old 04-08-2007, 07:48 PM   #8 (permalink)
sam_1710's Avatar
hey... use ur bluetooth dongle wid the bluesoleil drivers.. cos its deisgned to work only wid it!!..
AFAIK.. U cant install widcomm drivers for billionton dongles..
sam_1710 is offline
Old 04-08-2007, 09:43 PM   #9 (permalink)
bigdaddy486
Posts: n/a
plz explain me how? Also plz tell me how to browse and send files to my phone via bluetooth......
Old 04-08-2007, 09:49 PM   #10 (permalink)
sam_1710's Avatar
Uninstall both ur bluesoleil and widcomm.. restart ur pc..
Then insert the driver cd that came wid ur dongle or try the new version of bluesoleil from here. restart pc... then insert the dongle and run the software!!
then post the result!!
sam_1710 is offline
Old 04-08-2007, 09:52 PM   #11 (permalink)
bigdaddy486
Posts: n/a
But it willnot allow to browse my phone.......... How can i do that?
Old 05-08-2007, 01:22 AM   #12 (permalink)
Google Bot
Pathik's Avatar
u can browse ur fone thru bt only if ur fone supports it
Pathik is offline
Old 05-08-2007, 02:05 AM   #13 (permalink)
Back in Power
almighty's Avatar
download ivt bluesoleil 3.2
its compitble with vista too so it works for u
¡uʍop ǝpısdn ɹoʇıuoɯ ʎɯ pǝuɹnʇ oɥʍ ¡ʎǝɥ
almighty is offline
- by kool
