Old 04-08-2007, 01:05 PM   #1 (permalink)
Fortuna Favet Fortibus
amandeep86's Avatar
Question Replace 865GBF Motherboard With ???
I have a P4 2.8 GHz with HT Technology. A Intel Original 865GBF Motherboard.
512MB RAM @ 200 MHz. A nVidia FX-5200 Tornado 128 MB AGP Card. I want to upgrade my Desktop's Motherboard to a Vista Supporting. I think the Processor is 478-Pin Socket, if i'm not wrong. My Budget is around Rs.3000
Could you please suggest me?
amandeep86 is offline
Old 04-08-2007, 01:17 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Replace 865GBF Motherboard With ???
Sorry my frnd, Cant think of any Mobo with 478 support !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 04-08-2007, 01:22 PM   #3 (permalink)
Google Bot
Pathik's Avatar
i think a d101ggc wd do... but they r not available now..
btw if u have a gfx card then y do u need a mobo wit onboard gfx???
Pathik is offline
Old 04-08-2007, 01:22 PM   #4 (permalink)
Rebooting
Just for ur information D101GGC is one LGA 775
http://www.intel.com/products/mother...1GGC/index.htm
rebooting
ChotoCheeta.com
Old 04-08-2007, 08:15 PM   #5 (permalink)
amandeep86's Avatar
I went to Nehru Place (New Delhi) past thursday and found that Intel 3 GHz processor is available @ >Rs.3400. I should better sell my old Motherboard & Processor to someone and Buy a new set of Latest Processor & Motherboard.
But, what could i get under Rs.6000? Are AMD Processors Cheaper than Intel. Which one should i go for?
Old 04-08-2007, 08:35 PM   #6 (permalink)
Google Bot
Pathik's Avatar
@choto... yup my mistake.
btw yea amandeep if u hav a low budget u shd go for amd only..
but 6k is too low for a mobo+proccy..
Pathik is offline
Old 04-08-2007, 09:24 PM   #7 (permalink)
amandeep86's Avatar
Unhappy Another Problem
I'll stay with the current one.
But, today i'm in a trouble with my laptop. I'm getting a message on bluescreen and then the system restarts within 2-3 seconds. The message is something for adding of new hardware. Do i need a new Hard Disk. I currently have 40 GB Hard Disk. I do need a DVD ROM / Combo / DVD Writer. But, i don't know their prices. Can you suggest me Hard Disk & DVD Drive under 6k? I'll better invest that 6k here.
Old 05-08-2007, 10:50 AM   #8 (permalink)
can u be more descriptive of ur lappy problem . there must be some problem wiht a component . may or may not need replacement .
for ur desktop,
if u're not interested in gaming ( and u cant to it with ur rig ) , get a geforce6200 which will support vista aero . .its price will be around 2k .
sagargv is offline
Old 05-08-2007, 12:09 PM   #9 (permalink)
amandeep86's Avatar
Havn't got that message on my laptop again. Will surely read the error if seen again.
And about your AGP Suggestion, i don't need an AGP Card. I already have a nVidia FX-5200 Tornado (128-MB). I need a motherboard to support my current Intel P4 Socket 478-Pin 2.8 GHz with HT. My budget is around 3-4k.
Old 05-08-2007, 01:01 PM   #10 (permalink)
tech mighty
arun_chennai's Avatar
hi amandeep86 get E2140+ASUS 945G combo for 6k (3.1k+2.8k8))....great VFM...
arun_chennai is offline
Old 05-08-2007, 01:05 PM   #11 (permalink)
Mercury is offering support 478 pin motherboard PI865GVM u can try that
mskgadv is offline
Old 05-08-2007, 01:12 PM   #12 (permalink)
Google Bot
Pathik's Avatar
if u want a new 865 board then go for the asus p5p e
Pathik is offline
Old 05-08-2007, 01:23 PM   #13 (permalink)
Commander in Chief
QwertyManiac's Avatar
Hm, I got the same board but I don't understand what you mean by 'Vista-Supporting' one. All Vista doesn't give you on this board is good default audio drivers with lots of options but you can install the legendary SoundMax and begone with that trouble.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 05-08-2007, 07:11 PM   #14 (permalink)
amandeep86's Avatar
Thanks. That was what i was looking for.
Auto on in Intel 865GBF cyberzook Hardware Q&A 5 24-06-2006 04:34 PM
865GBF mother board vinu Hardware Q&A 1 26-04-2006 02:24 PM
intel 865GBF readermaniax Gamerz 4 08-12-2005 10:19 AM
which is better intel 865GBF or 865PE abhasbajpai CPU / Motherboards 13 28-08-2004 01:54 PM
- by kool
