Old 04-08-2007, 10:40 AM   #1 (permalink)
Always Questioning?
emailaatif786's Avatar
Angry MT882 Firmware
Anyone, please give me the correct link to download MT882 Firmware?
I have MT882, but shows MT880!
:smile: Love Digit
emailaatif786 is offline
Old 04-08-2007, 11:58 AM   #2 (permalink)
slugger's Avatar
Default Re: MT882 Firmware
its not the firmware u shud b searchin 4 but d correct modem drivers. u shud have been given a CD by d BSNL guys along with d modem kit. the CD has on its label , printed the model no 4 which d drivers r ment
just check out d CD and if you see a diff model no 880
get it replaced from d bsnl office
u will also get d drivers HERE
but u shud also go get a copy from BSNL
it is der friggin duty 2 provide u with correct stuff
slugger is offline
Old 04-08-2007, 12:05 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
@emailaatif786
Modem seems hey wire
Contact the BSNL dudes,. see it shows ur down stream Bandwidth 1152 kbps and upstream 446, where as its suppose to be 2048 for down stream and 512 for upstream...
means at this point even if u have a upto 2mbps connection ur modem is not allowing u to use 2mbps, as its stuck at 1152kbps...
this is BSNL fault, ask them to solve this issue
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 04-08-2007, 12:37 PM   #4 (permalink)
slugger's Avatar
Originally Posted by Choto Cheeta
@emailaatif786
can it not b bcos he has installed the wrong modem drivers, as he has already mentioned in his post
becos of the wrong drivers he is not gettin optimum performance
so if it really a smartax 882 u must install d correct drivers first and den c ur upstream and downstream rates
slugger is offline
Old 04-08-2007, 02:08 PM   #5 (permalink)
Always Questioning?
Wink Re: MT882 Firmware
@emailaatif786
There is no Driver problem.
I has updated my Modem's Firmware, but it got downgraded to MT880. Now I want to download the MT882 firmware, and please reply that where can I download it?
There is GREAT Difference between FIRMWARE and DRIVER. FIRMWARE is JUST like its OS and Driver is to Recognize its OS!
Anyone, please give me the correct link to download MT882 Firmware BUT not the Driver?
:smile: Love Digit
Last edited by emailaatif786; 04-08-2007 at 02:09 PM. Reason: Automerged Doublepost
Old 04-08-2007, 02:44 PM   #6 (permalink)
slugger's Avatar
u will find d original 882 firmware HERE
you will find d newer firmware HERE
sinc u happen 2 no so much abt d diff betn firmware and drivers, u shud also no d Cardinal rule of posting on forums
DON' START THREADS 2 SOLVE PROBLEMS DAT IS EASILY RESOLVE USING GOOGLE!!!!
slugger is offline
Old 04-08-2007, 05:23 PM   #7 (permalink)
Always Questioning?
Smile Re: MT882 Firmware
[QUOTE=slugger]
DON' START THREADS 2 SOLVE PROBLEMS DAT IS EASILY RESOLVE USING GOOGLEQUOTE]
Thankyou
I searched hard on Google, but did'nt find and then only I Posted the Q here!
:smile: Love Digit
BroadBand user of BSNL...any tweaks for MT882??? shyamno Hardware Q&A 10 24-01-2007 08:59 PM
My SmartAX MT882 Router cannot be detected. emailaatif786 Hardware Q&A 4 02-01-2007 08:06 PM
mt882 using yast 2 chintanraoh Open Source 10 23-06-2006 11:52 AM
- by kool
