Old 03-08-2007, 08:59 PM   #1 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Need a No-nonse ADSL modem for Dataone
I need a simple router which should work with my dataone, do not need wifi as i already have a wifi router(tp-link).
i need a compact router which can take load of long hours of running together.
i have a few models in my mind suggest which one, also if there is something better than these
D-link 502T
Netgear ADSL Modem DM111P
Netgear DG632 ADSL Modem Router
Price from theitdepot.com
D-link @1730/-
Netwgear DM111P @ Rs 1540
Netgear DG632 ADSL Modem Router@ 1750
which one to buy in lowest possible budget keeping in a decent performance in mind, i am confused as all three of them are in same range
BUDGET:around 1.5k
gary4gar is offline
Old 03-08-2007, 10:06 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Need a No-nonse ADSL modem for Dataone
Whats wrong with out BSNL own modems ??
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 03-08-2007, 10:15 PM   #3 (permalink)
left this forum longback
praka123's Avatar
^i want to change my huawei MT 880(rental) they gave approx 2 yrs before.can i get a replacement -a latest ustarcom one or any new one because i find no usb option in this piece what reason can i put?
praka123 is offline
Old 03-08-2007, 10:19 PM   #4 (permalink)
Rebooting
what u just wrote here ...
I hear guy in Kerala BSNL a really educated from other forum members in diferent UGs, they will help u, just talk to ur DE (INT)
for here in Kolkata, well one has to do a lot of papaer work with tons of Technical term so that they can understand what u are writing and without much argue.. they will change the modem
rebooting
ChotoCheeta.com
Old 05-08-2007, 08:47 PM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
Only if they are available, the only ones available(TYPE-II & IV) here are costing me 2022+250=2272
where as i can get one modem from market at 1.5k, also they will be of good company instead of some unknown company like huawei and that too chinese
also when getting a modem from bsnl means there so call engineers will visit my place, as my both parents are working & me also going to college all they will find is a BIG lock. so apart from money thats also i problem.
Please suggest some between d-link & netgear
gary4gar is offline
Old 06-08-2007, 04:32 AM   #6 (permalink)
praka123's Avatar
D-Link -seems most ppl prefer.
praka123 is offline
Old 06-08-2007, 12:19 PM   #7 (permalink)
=CrAzYG33K='s Avatar
DLINK GLB 502-T
My Choice
PS : Works with both Airtel and BSNL
\\~o~// SpId3Y FaN \\~o~//
=CrAzYG33K= is offline
Old 07-08-2007, 06:11 AM   #8 (permalink)
Vivek788's Avatar
but still my modem has lots of complaints...will they replace it becos I had bought it outright...?
Vivek788 is offline
Old 07-08-2007, 01:19 PM   #9 (permalink)
GaurishSharma.com
gary4gar's Avatar
i know about D-link it tried and tested.
i like the form factor & rounded shape of the netgear ADSL Modem DM111P any body tried that??. the netgear is more compact that d-link
whats difference between the two only looks or some functional difference as well?? if only looks then netgear is my choice otherwise if d-link offers better functionality than netgear i can sacrifice of looks department.
gary4gar is offline
Old 07-08-2007, 01:50 PM   #10 (permalink)
damn busy...
utsav's Avatar
i am also going to get a bsnl connection next month.i want to know that if bsnl increases the speed say from 2mbps to 4mbps do i hav 2 get a new router or the same router will support it.
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 07-08-2007, 09:39 PM   #11 (permalink)
gowtham's Avatar
no u need not get a new modem as nearly all adsl modems support 8mbps and i have heard that the maximum theoratical limit for ADSL is 24 mbps! so need to upgrade ur modem any time in the near future!
There is always a better way to do it. Go find it!
Thomas Alava Edison
gowtham is offline
Old 08-08-2007, 01:08 AM   #12 (permalink)
GaurishSharma.com
gary4gar's Avatar
whats the current price of Dlink router in north region??
gary4gar is offline
Old 08-08-2007, 02:02 PM   #13 (permalink)
damn busy...
utsav's Avatar
there is a lack of availability of dlink in my city.it seems i hav to go to gwalior or bhopal to get a modem
www.techjunkiez.com
utsav is offline
Old 10-08-2007, 02:50 PM   #14 (permalink)
I bought a dlink glb-502t here in bangalore for Rs.1650 a month ago. Sometimes it wont connect, if u restart the modem it will connect. There a still a few bugs in this one. There is also no switch-off option at the back of the modem like they had for their dialup external modems. If u want to turn off the modem, you will have to remove the power plug from the back side. don't know if its harmful to the modem. sometimes my modem behaves weird if i remove the power plug and insert it...it won't connect at all...happens sometimes only.
casual_gamer is offline
Old 10-08-2007, 07:26 PM   #15 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
^^... One of my friend is having the same problem with a DLink.. Thats the reason he doesnt use PPPOE ..
My hacked MT880 works fine on my system .. and its close to two years old now ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 10-08-2007, 08:22 PM   #16 (permalink)
now my adsl light started blinking in dlink glb-502t. i removed the power plug and put it on after 10 minutes, and now the adsl light is stable and am able to connect to net. this is happening alot from the past 1 week, i should have trusted all the negative reviews i read on the net. but still i went with dlink coz of the brand name, now i am cursing myself. plz don't make the same mistake as i did.
Old 10-08-2007, 08:24 PM   #17 (permalink)
Rebooting
Tell u one thing, these BSNL modems are Rock Stable... !!!!
Used all most all type till now, and see even doing 24x7 non stop for 1 year... no problem what so ever !!!
rebooting
ChotoCheeta.com
Old 11-08-2007, 12:21 AM   #18 (permalink)
GaurishSharma.com
gary4gar's Avatar
me to read a lot about d-link heating problems, seems i will part my way from d-link.
now i have to options to go with the Bsnl modems or get netgear. i think neatgear should be safe bet:-
gary4gar is offline
Old 11-08-2007, 01:16 AM   #19 (permalink)
praka123's Avatar
Smile Re: Need a No-nonse ADSL modem for Dataone
BINGO!hacked?(mt882 firmware )?
praka123 is offline
Old 11-08-2007, 11:43 AM   #20 (permalink)
damn busy...
utsav's Avatar
i think bsnl type 1 modem is ok for me and what is the warranty period & expected price .they say on their site that its price is Rs 1200.
www.techjunkiez.com
utsav is offline
Old 11-08-2007, 11:47 AM   #21 (permalink)
Rebooting
cant say about other places in Calcutta Telephones things work differenet
Theoritically its One year, but if u can do a little paper job, they will not only change the modem after 1 year but will give Type - IV if needed
rebooting
ChotoCheeta.com
Old 12-08-2007, 01:16 PM   #22 (permalink)
damn busy...
utsav's Avatar
Exclamation Re: Need a No-nonse ADSL modem for Dataone
how give some details
www.techjunkiez.com
utsav is offline
Old 13-08-2007, 02:07 AM   #23 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
yesterday i bought D-link GLB-502T its working fine@2000(1900 D.P rate) or u can buy surecome modem
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Which ADSL Modem? jack// ani Networking 13 24-07-2008 09:37 PM
Configuring the Dataone Connection and ADSL modem in SUSE 10.1 Techie_Geek Open Source 2 07-08-2006 10:06 AM
dataone (ADSL) modem availability ...???? vijay_7287 Networking 4 23-11-2005 03:34 PM
what type of ADSL modem do BSNL DATAONE & AIRTEL BROADBAND? nitish Broadband and DTH 11 07-05-2005 07:56 PM
- by kool
