Originally Posted by xbonez
it'll still be in guarantee period so nothing to worry about. j
Yeah. It has 2 years warranty, and I bought it only about 4 months ago. The only problem is that right now I am in Bangalore, and I am from Kerala.
Originally Posted by sashijoseph
You've tried the cd which came along with it?
And do you keep the play/pause button pressed while connecting the tsonic to the usb cable?
I have tried the recovery software from the CD. It had 3.3 firmware version. It flashed correctly, but the initial problem that I mentioned in the first post still existed. So I decided to try 3.1 firmware. Earlier, when I had 3.4 firmware in the player, if I try to flash with 3.1's utility, flashing fails and the player wouldn't boot anymore. Even then, if I connect it to the computer, the player will be detected as
Player Recovery Class or some name like that in Device Manager. But this time, 3.1 firmware installed correctly. After that, player is not booting up, and it is not detected by the computer. It seems the player is totally dead.
I'd recommend installing the recovery s/w from the cd,pressing the play button,connecting the usb cable and keeping the play button pressed for a few seconds till it gets detected in recovery mode.
I will try it and will post back about the result. I strongly hope that this will work.
Pls pray for my player.
