Old 01-08-2007, 09:12 PM   #1 (permalink)
thrash_metal's Avatar
Default Home Network using Linksys + ADSL
I have a TataIndicom 512unlimited connection . The router IS Billion BiPAC 5200(S) ADSL . Now I also have a Linksys WRT54G wireless router . The aim is to connect my pc , another friends pc and my xbox360 wireless/wired so that all can access the internet as well as data transfer between them . I tried using the setup which came on with the Linksys ... but the setup STOPS at step 10 "saying that cannot access the internet" , I triple checked all the connections and they are correct , although I'm a n00b in networking department ...... Can anyone help me configure all these properly ?
The connection right now is :-
My pc -> Linksys WRT54G -> Billion BiPAC 5200S -> Internet
IF I directly connect the adsl router to the pc ..the inter is working fine , the moment I connect the Linksys all problems start !!!! A dude told me about some ADSL router settings but even he was unsure of ..... any ideas ???
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
thrash_metal is offline
Old 02-08-2007, 12:37 PM   #2 (permalink)
Default Re: Home Network using Linksys + ADSL
may be indiom have registered your machine's mac address so that other can not use the net from ur line..
scorpionzzz is offline
Old 04-08-2007, 09:48 PM   #3 (permalink)
pedal to metal
suave_guy's Avatar
go to the linksys website and download a tool from their troubleshooting section called "netstat"...its a stepwise troubleshooting guide and should automatically correct ur settings...
your "attitude" is your best friend...
suave_guy is offline
Building a WiFi home network!! invisiblerohit Networking 3 16-06-2007 05:52 PM
Requirements for Setting Up A Home Network caje143 Software Q&A 2 05-04-2007 04:52 AM
How To Secure Your Home Network Third Eye Technology News 2 09-03-2007 02:16 AM
Home network WiFi Help ashkom Networking 3 24-07-2006 01:38 AM
need help in deciding the type of network in my home yash Networking 10 28-02-2005 10:00 PM
- by kool
