hi i hav a Audigy 2 ZS platinum pro.
i am using it in 7.1 configuration, such that the Front L/R goto Line in of Hi-Fi Music System and other channels goto a Artis X10 - 5.1 speaker system.
I am using the 3.5" -> 3 RCA cable that is similar to the cable dat comes wid Camcorders(i.e audio L/R,Video on a single jack,basically 3 channels on one jack instead of regular 2 channels)
For 7.1 two such cables are plugged in, and the appropriate RCA jacks go to the Speaker input of the 5.1 System.
My problem is that of a channel leakage.
The Center,Side Left,Side Right channels seem to be mixed up.
i.e the Center sounds come thru the Side Left as well as Side right speakers.
same happens with Side L,Side R.
i.e basically all three channels come from all three speakers.
(though the sound is louder from its intended speaker it still is audible from the other 2 speakers)
This DOES NOT happen with Real Left/Rear Right channels and they sound as they should.(and they too are on another 3 channel 3.5" jack)
The things i have checked are:
-CMSS is turned OFF
-I have tried interchanging the 3.5" -> 3 RCA cables
-Theres no Upmix enabled on the 5.1 Speaker set, so input is 5.1 nd output is 5.1 unaltered
Why is this happening? is dis because of the cable?
Is there any solution?
would be glad if somebody could help me out.......
