Old 31-07-2007, 09:58 PM   #1 (permalink)
EXPLORING!!!!!
sid_sh85's Avatar
Default AMD or INTEL????????????
Hi guys....pls help me....m considering an upgrade for my sys....either an intel e4300 with orignal intel board or an amd 4800+ with an equivalent...now my major concern is dat i m using an amd machine....n to b frank m not satisfied with the performance due to sum overheating issues....so this time i dnt wanna make any mistakes as i wud b using the upgraded sys atleast for the nxt 2 yrs or so.....so pls advice me....whether i shud stick to amd or switch over to intel....do intel machines also giv heating probs???? pls advise.......THANX
and yes, pls suggest sum gud proccy n mobo combos..cuz i wud b adding a geforce 8600gt 256mb to the upgrade
_____________________________________________
AMD Phenom II 920__GIGABYTE GA-MA78GM__1.75TB HDDs__6GB DDR2__CORSAIR VX550___ZOTAC GTS 450 Amp Ed!!___Samsung Syncmaster B2230__DELL INSP 15
sid_sh85 is offline
Old 31-07-2007, 10:12 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: AMD or INTEL????????????
May be u missed this
http://www.thinkdigit.com/forum/showthread.php?t=63874
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 31-07-2007, 10:29 PM   #3 (permalink)
EXPLORING!!!!!
sid_sh85's Avatar
Ya choto...thanx for the suggestion...i did go thru the post...but u see....i wanted sum info abt the overheating issues wich r generally seen in amd cpu...so wot abt tht...does intel too heat up like amd????
sid_sh85 is offline
Old 31-07-2007, 10:32 PM   #4 (permalink)
Rebooting
The reason of that post was to try and sum up all these Config related questions
Over Over heating issue....
Overheating problems
rebooting
ChotoCheeta.com
Old 31-07-2007, 10:44 PM   #5 (permalink)
EXPLORING!!!!!
sid_sh85's Avatar
Thanx a zillion choto...but uh..well...u see...errr...i um....actually cud u pls cut it short for me n sum up??? i mean jst declare clearly...
1)wich one is hotter...amd or intel...also, in terms of durability
2)n performance-wise, which one rules the roost....intel E4300 or the AMD 4800+......
also remember dat i wud b adding an 8600gt grpx card and 1gbddr2 ram on a gud Moboard to it...so pls specify....thanx
sid_sh85 is offline
Old 31-07-2007, 10:46 PM   #6 (permalink)
Rebooting
All depends on the budget !!!
AMD and Core 2 Duo are both runs quite cool, both and good overclockers
rebooting
ChotoCheeta.com
Old 31-07-2007, 10:50 PM   #7 (permalink)
EXPLORING!!!!!
sid_sh85's Avatar
okey...my budget for the upgrade of 1)ram, 2)cpu n 3)board is 15k....i normally work on 3ds max n m a not-so-hardcore gamer too....also i wud b adding 8600gt grpx later on...dats the reason for the tight budget...sp pls advise
sid_sh85 is offline
AMD SELLS INTEL CPUs... HAS IT COMPLETELY LOST THE WAR WITH INTEL C2D vish786 Technology News 9 09-06-2007 07:46 AM
Intel mobo for Intel Core 2 Duo E6300 !! kaps_2222 Hardware Q&A 3 21-04-2007 10:32 AM
INTEL 865 GBF techsammy Hardware Q&A 7 27-03-2006 06:56 PM
amd or intel???? amrit1 CPU / Motherboards 2 24-03-2006 11:26 PM
Which is best.--->Intel 915P or Intel 915G vps85 CPU / Motherboards 5 20-01-2005 08:57 PM
- by kool
