Old 31-07-2007, 04:16 PM   #1 (permalink)
Default Query abt LCD Widescreen Monitor....
Hi guys,
I have a query regarding widescreen lcd monitor. I am gonna build a C2D based pc on weekend.
I got to know that onboard graphics cards do not support lcd mionitors. Is it true?
I am planning to go for a motherboard with onboard graphics and a widescreen lcd monitor. Should I buy a separate graphics card also?
Please help asap!
Regards,
Amit.
amitskale is offline
Old 31-07-2007, 04:56 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Query abt LCD Widescreen Monitor....
Not true... any onboard grfx will support the LCD but if weak onboard grfx then will have problem running the LCD on optimal Resolution...
U can refer here
http://www.thinkdigit.com/forum/showthread.php?t=63874
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 31-07-2007, 06:29 PM   #3 (permalink)
Thanks for the reply cheeta. I have already referred the link u have mentioned. I did not get the answer to my quey there.
Anyway, I will reformat the question.
If I am going for E6550 with a decent onboard motherboard with inbuilt gfx card then will the display on lcd widescreen would be alright. Meaning there should not be the problems like extra blurr or no support for resolution etc.
Please help me on these lines.
Thanks in advance!
Regards,
Amit.
Old 31-07-2007, 06:58 PM   #4 (permalink)
Rebooting
Soul reason for the thread was to sum up all these question to one thread... but its not my call rather its the mods call !!!
anyway just to answer the question...
I hav already suggested few option on that Sticky, as there are not much board with onboard grfx for FSB 1333 processors.....
Now still now good news with Intel G33 boards with onboard X3100, though I was told that DG33TL model would be priced bellow DG965RY model... !!! but still waiting for official News... !!! even if u get one of those, will mean no Overclocking for the procy...
No News for the ASUS G33 based either on indian Market !!!
So choise left is Rs. 5000/- + TAX XFX 650i Ultra couple with any Cheap 7xxx seris card like 7100 / 7300 for or under Rs. 3k !!!!
P.S. all these info was given on that thread !!!
rebooting
ChotoCheeta.com
Old 01-08-2007, 10:26 AM   #5 (permalink)
Yes, cheeta. I have read all that.
But in my query I have not asked anything abt compatible motherboards or so. The only thing I have asked is - Does onboard graphics card give good picture quality for the widescreen lcd or not?
I am not into gaming and so don't want to go for a separate graphics card. If inbuilt graphics does not give good performance then later I will have to go for separate graphics card which would be a costly affair.
That's why was asking...
Regards,
Amit.
Old 01-08-2007, 10:41 AM   #6 (permalink)
Learner
Kniwor's Avatar
Regards,
Amit.
mention what motherboard u are looking at buying. Some integrated solutions do support 16:10 resolution settings, and some do not, be specific.
Kniwor is offline
Old 01-08-2007, 11:00 AM   #7 (permalink)
I am planning to go for P5K-VM or P5B-VM.
Pls suggest if these support the 16..10 resolution. Also I am going for Viewsonic widescreen 19'' lcd monitor.
Thanks,
Amit.
Old 02-08-2007, 07:24 PM   #8 (permalink)
Ex-KGB
Im also in similar dilemma .. i want to buy a Widescreen 19" LCD .. but my graphics card is an old dusty MSI GeForce FX 5200 . Is buying the LCD a gud idea ?
Btw i heard somewhere with low end graphics cards ..one should use the D-Sub ouput for Widescreen LCD to get the optimal resolution and not the DVI .
So original poster might consider that as well . Hope that helps
Cheers.
avikchaks is offline
Old 03-08-2007, 11:37 AM   #9 (permalink)
Still no replies to this? Guys pls help!
I am in urgent need for this advice. Should I go for a separate graphics card or not?
Thanks in advance!
Regards,
Amit Kale.
Old 03-08-2007, 12:34 PM   #10 (permalink)
Rebooting
Well my frnd, i dont think u read that sticky right...
with FSB 1333 processors u cant buy P5b-VM.... and about asus P35 based ones, i have doubt over their availibility and some high price issue tooo...
did u consider XFX 650i Ultra / P5N-E SLi / P5N32-E SLi / XFX 680i SLi ?? with even a 8400 GS would give ur LCD a better flatform !!!
rebooting
ChotoCheeta.com
Old 03-08-2007, 12:51 PM   #11 (permalink)
Dear Choto Cheeta,
with due respect to u, i guess u are not reading my query properly.
I am not in a search of a motherboard.
My query is - if I use any of these motherboards (P5V/VM or P5B-VM) then whether widescreen lcd monitor will give the same quality of display for inbuilt display card as that of a separate graphics card?
Pls note that I am not into gaming at all.
Will u pls reply to this if u have any info?
Thanks and Regards,
Amit.
Old 03-08-2007, 01:08 PM   #12 (permalink)
Rebooting
well, just asnwering that question...
I donbt have any Practical EXP with P5V, how ever I have used, or tested, VG1930WM (19" Widescreen) with P5B-V (GAM x3000) Intel DG965WH (X3000), BIOSTAR board (AMD plaform) onboard Nvida 6150, ASUS M2A-VM (ATi x1250)
all run fine with with the Highest Resolution supported 1440x900 run 720p HD without any issue... !!!
also Tested with my frds lappy came with X3100 based GAM (HP Lappy mobide G965 X3100) run fine with its output too !!!
rebooting
ChotoCheeta.com
Old 03-08-2007, 02:17 PM   #13 (permalink)
Oh, thanks! That was the reply I was looking for choto cheeta.
I will go for inbuild graphics card motherboard now.
Regards,
Amit.
Old 03-08-2007, 02:33 PM   #14 (permalink)
Rebooting
Tell me, whats the budget ?? as see if u plan to buy a P5B-VM (Rs. 7k+TAX) then i wuld say better buy would be XFX 650i Ultra (5k+TAX) with 8400 GS (2.8k+TAX)
rebooting
ChotoCheeta.com
Old 03-08-2007, 02:54 PM   #15 (permalink)
Hey Choto Cheeta,
Budget is around 7k. But I am ready to extend it till 9k if there is compelling reason.
Please suggest me what you want to.
Regards,
Amit.
Old 03-08-2007, 02:56 PM   #16 (permalink)
Rebooting
Once again, when u can afford a little extra then i would say, XFX 650i ulta with 8400 GS over Intel GMA X3000 ..
rebooting
ChotoCheeta.com
Old 03-08-2007, 03:11 PM   #17 (permalink)
Thanks a lot Cheeta for the reply and all the help u did!
I will go for XFX 650i ulta with 8400 GS.
Regards,
Amit.
Old 03-08-2007, 09:42 PM   #18 (permalink)
thats the far far far better option .choto , u always seem to suggest the best thing .keep ruling man . ..
sagargv is offline
Old 03-08-2007, 09:46 PM   #19 (permalink)
Rebooting
Thnx for the comment buddy
rebooting
ChotoCheeta.com
Old 04-08-2007, 10:54 AM   #20 (permalink)
welcome .i meant every word i said . i aint flaterring.
sagargv is offline
22" Widescreen LCD @ 19,000! godling Hardware Q&A 20 13-06-2007 04:48 PM
Widescreen Dillema topgear Hardware Q&A 20 27-05-2007 05:30 AM
Widescreen help + 1 small query... gannu_rox Hardware Q&A 3 25-05-2007 05:52 PM
widescreen LCD gksunil Hardware Q&A 3 23-04-2007 03:40 PM
Microtek Monitor Query and PHPBB Attachment Mod Query vwad Software Q&A 1 20-03-2005 09:32 AM
- by kool
